Cool thing to have if your Auto Crossing, tracking or dynoing your C5!
Supporting Vendor
There's a lot of benefits to keeping your Vette cool!
Here is SacCityCorvette’s latest version of the Cool It v2 and v3 Remote High Speed Fan Controller for your 1997-2004 C5 and C5 Zo6.
Now you can control your C5 Corvette's radiator high speed cooling fan with the simple push of a button on your wireless FOB, allowing you to control your radiator coolant temps. No need to pay for a expensive tune to change your fans on/off temperatures or running you’re A/C to cool the engine, along with all the unnecessary wear and tear and fuel mileage loss that goes along with running the A/C.
The Cool It v2 and v3 now run on their own circuit and will not interfere with the normal computer controlled operation of your cooling fans.
Installing the Cool It v2 and v3 is a very simple five minute plug and play installation. (See our installation video) After you install the Cool It v2 or v3, you will be able to turn on the right side cooling fan on in high speed mode using a wireless FOB making it perfect for when you are at the track and you want to cool down between runs, in traffic and idling in parades. It will even help keep your Automatic Transmission running cooler too!
That’s why you should have a Cool It!
Only $99.95! Watch our installation video and see how easy it is to install the Cool It!
http://www.saccitycorvette.com/Cool-...sll-video.html
Here is a link with more information!
http://www.saccitycorvette.com/COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
It's cool to just push a button and cool your engine down!
Supporting Vendor
Warm weather is coming! Your Vette will appreciate having
a CoolIt on it!
a CoolIt on it!
Supporting Vendor
Don't wait until your sitting in traffic with your temp going up and down between 220-230 degrees and you automatic transmission getting hot too! It only takes 5 minutes to install a CoolIt and you will be able to push a button and watch your temps drop!
Supporting Vendor
We have the Race version of the CoolIt v2/v3 coming soon for you racers that want to cool down between races. Unlike the standard CoolIt v2/v3, the “R” series CoolIt allows you to run your radiator fan in high speed mode with the key off making it perfect for drag racing because you can cool down after a run while sitting in the staging lanes and keep your C5 cool during the burn out and throughout the run. Also great for Autocross and you can still use in on the street. The CoolIt v2/v3 R still retains the simple plug and play design.
Supporting Vendor
The CoolIt will help keep your automatic trans cool too!
