Drag Racing Helmet
Old 02-11-2012, 02:11 PM
SLOWEST Z
SLOWEST Z's Avatar
Default Drag Racing Helmet
Which helmet would be recommended for Drag Strip?
What is your thoughts about this?
http://www.hjc-helmets.com/product/SUL906911-ATT.html
How do I know that it's NHRA approved for drag race strip use?
Old 02-12-2012, 01:42 AM
stevensa
stevensa's Avatar
Wrong forum, but anything SA2005 or SA2010 will be fine.
The helmet you listed says this
"Meets or Exceeds SNELL 2010 & DOT Standards (3XL DOT only] "
I would check to see if it actually has a Snell SA rating, if it doesnt it may not pass tech.
Old 02-12-2012, 08:11 AM
AU N EGL
AU N EGL's Avatar
anything that says
"Meets or Exceeds SNELL 2010 & DOT Standards " stay away from
HJC does have helmets that have the "SNELL SA 2010" rating and that is what you want
To Drag Racing Helmet
Quick Reply: Drag Racing Helmet
