Steering Wheel
I used a 330mm Sparco for a couple of events and it was just too small for me. I bought a 350mm MOMO and it's perfect.
Steering wheel:
http://www.amazon.com/Momo-R1909_35S...9063543&sr=8-1
Quick Release Hub:
http://www.summitracing.com/parts/GRT-3021/
2 inch spacer:
http://www.summitracing.com/parts/GRT-4000/
Grant to Momo adapter:
http://www.summitracing.com/parts/GRT-4009/
Steering wheel:
Quick Release Hub:
2 inch spacer:
St. Jude Donor '05-'08
I was looking at this one but didnt know if 350 was too big.
Does anyone know the standard size?
I assume you need all of compionents to make the MOMO fit correctly.
Steering wheel:
Quick Release Hub:
2 inch spacer:
Steering wheel:
Quick Release Hub:
2 inch spacer:
I did a lot of searching and question asking about this last year when I got my track car. After many suggestions, the consensus at that time was to go with the ATI quick release HUB. If you go through them, they have a complete kit with everything you need. There's an old thread around that has some pictures and lots of good info. I went with the Sparco 383 330mm wheel for my car and love it. For me, it's just the right size. It is much smaller than the stock steering wheel. You will think you are driving a bus when you go to the stocker. ATI can also get the wheel for you as well so you can get everything from one place.
I forget who the contact is...I want to say Adam but not sure. Their phone number is 248-848-9200.
Jay
Jay
Jay
Jay
Bob heres a great thread that should help.
http://forums.corvetteforum.com/auto...-wheels-5.html
I am in the process of doing the same thing, if you look at post 81, this is the exact setup I plan on using.
and I think stock is 380mm
Hope it helps Nando
Hope it helps Nando
Quick Release Hub:
2 inch spacer:
2 inch spacer:
