I need a bolt in Race Seat for 11 GS...any suggestions
I would like to find a bolt in race seat that I can pull out stock seat and race seat would bolt down to stock hardware...any sources?
Received 8,928 Likes
By bolting to stock hardware do you mean to the stock seat tracks?
Bill
Bill
It probably is easier to leave the stock seat attached to its tracks and just throw in a race seat on a set of mounting rails or a stock manual seat track. To get the seat frame off the track you have to pull the bottom seat cushion. When you pull the stock driver's seat out you will lose the telescopic steering since it depends on the memory module fastened to the springs of the seat.
Bill
Bill
Bill
Bill
sparco pro 2000
Sparco Pro 2000 fits w/ a slider. This one is very comfortable for my body. I wear a 42 or 43 suit. This also comes in and out of the car pretty easily, but it is so easy on me that I keep it in. The seat was sitting up too straight for me, so I added about an 1 1/2" to the bottom around the two front bolt holes to tilt this back slightly.
Any easy fixes....bolt in seats?
Step 1: Pick a race seat that fits you.
Step 2: Buy Hardbar seat rails.
Step 3: Install in car for track events
Not sure why this is so hard? As for the stock seats... they're made for fat older people who want to take road trips... and they're wonderful for that.
Location: If you don't weigh in you don't wrestle Road America
You could look at the Carravaggio seats, they mount to the stock seat tracks but they are $$$$ as heck.
Otherwise find a seat that fits you - go someplace that has a lot of different seats in stock so you can test fit them.
This is what I use, seat, sub and lap harness all comes out together.
http://www.ipsmotorsports.net/catalo...oducts_id=3470
I did not see the seat mount on pfadt website, I don't know if they still make them.
You can put a manual slider between bracket and seat if you want the seat to be adjustable. If you are tall skip the slider. If you need a slider I have one made by Sparco that I would sell. I was too tall to use the slider with a helmet on.
Bill
[QUOTE=Bill Dearborn;1580033747]First thing to do is to make sure you use the stock harness cinch feature properly. At 6' 1" you may already have the seat all the way back but make sure you pull the belt all the way out until it starts ratcheting when it takes up the slack. Click it closed and use your right hand placed on the shoulder belt portion just above the latch to pull the lap belt tight. Once tight hold it there and use your left hand to feed the shoulder belt portion into the take up reel behind your shoulder. Repeat this several times until the belt is tight across your chest and lap. If you can move the seat forward do so. If you can move it far enough forward to make the belt tight enough to be painful across your pelvis it is almost tight enough. It will actually keep your butt from sliding around in the seat but your upper and lower body will pivot around your butt. You still need to use your knees to brace your legs so they don't swing back and forth. This is a cheap fix and works for fairly heavy G loads. You may already know this but I have found most Corvette owners don't know about the feature and non of the magazine evaluators know about it.
Bill[/QUOTE
I will try this out before spend the $$$$ on a new seat..tx
Bill[/QUOTE
About 1 inch. I am 6'-0" with slider and headliner installed with my helmet on the helmet just barely touched the headliner. With headliner removed and slider removed there is about 1-2" between helmet and roof. Still a little tight. There are many variables, torso length, seat braket height, how much seat is reclined etc. to take into consideration.
Here is another consideration if you know an excellent upholsterer. I have been thinking about this quite a bit. First, we know GM extended the shoulder supports slightly for the 12 model year. Following the same reasoning why not work with an upholster that could design and build a lay out that extends support for the shoulders even more than GM did plus add larger/higher bolsters in the seat bottom area to hold a person's legs in place. With the upper and lower body restrained from moving side to side the factory seat belt cinched tightly would probably provide enough support to allow some fairly high G cornering without popping for a race seat. Basically the mods would deepen the bucket and hold a person in the seat better similar to the early C4 seats. One big concern is to make sure the seat mods don't block the side air bag deployment area.
The mods would be a set of Custom foam blocks that fit on the seat bottom and back along with Custom seat skins. When you want to sell the car you pull the seats out and swap the stock foam and skins back into the car. I think Apsis did something like this but loaded the seat up with expensive leather rather some cheap, long lasting covering.
Bill
Bill
This is how I do it.
My plan was to make a set up that would allow me to quickly swap out my stock seat (which I use for daily driving) with a race seat for HPDE's. I also want the airbags to be active for the trip to and from the track. I am using the Vetteworks Simulators. But, the normal installation requires pulling the stock harness out of the stock seat. To make the switch out easier I ordered a replacement seat harness from one of the forum vendors. Seat harnesses can be ordered two ways....with heat and memory....or without. The harness without heat and memory is only ~$25 (vs. $100+ for the other one). In addition to the harness you will need three plug in simulators (two for pre '08 cars). One simulator is for the seat airbag, the second is for the seat position sensor, the third (for '08+ cars) is for the seat belt pretensioner.
Here is a picture of the three simulators. The two yellow simulators (airbag and pretensioner)fit together and make one plug. The black plug attaches to the harness and simulates the seat position sensor.
Here is a picture of the harness (without heat and memory).
Here is a picture of how I modified the harness. You only need the pink and green wires going to the seat position sensor (or simulator in this case)
This is what the seat area looks like with no seat. The yellow plug is for the seat airbag (and pretensioner in '08+ cars). This is where the two yellow simulators plug in. The wide black plug is where the harness plugs in for the seat track simulator. The black simulator plugs into the other end of the harness.
Cobra Suzuka Pro GT on Arizen slider and Scroth Profi 6 point harness.
Here is the seat in the car (The sholder harnesses go on with the roll bar at the track
Looking down on the seat with the door closed
Tom
Can you give my the info on your seat...Can it move back and forth? I want the identical set up..It looks easy... It looks like there are 3 plugs in the floor of the cars...I got the yellow plug..(airbag), The modified harness I understand too...what the third? do you attach the harness to the race seat???
