Stock Corvette Hubs/Spindles with Race Rubber
How fragile are the stock units?
I am having custom spindles made by Cortex for the car. The Cortex guys want to run the car first with the stock setup and then run back to back with their stuff--which is understandable for their info.
It would be easier if we just had the new spindles setup with new SKF hubs and ready to go, and I just ran the old/stock spindles and hubs for that baseline rather than have to swap it all over in a test day.
Will the stockers be alright for a half a test day or maybe up to two test days if we need to debug stuff? This would be with FULL RACE rubber...315 fr and 335 rr Hoosier A6 type of rubber.
Thanks!
Thanks!
not only are the OEM units durable, but there are at least 3 companies already making billet spindles. I've never broken an upright, even when I smashed them into concrete during street-course races (even though I snapped the rotor in half)
The company who will make my spindles are expanding their current line. Since I am offering them access to a Corvette platform, they are doing it for a bargain to me. The product on the Camaro was second to none the way it came out.....so....why not?? Will get all the advantages of "the industry standard" drop spindles that most use at a smaller cost.
This car is going be fun. I hope to avoid the PAINFUL development of my Camaro.....buying what I could afford at the time, then completely throwing out 90% of it a year or two later for "the next step up" the ladder, then doing it all again 2 years later. The Camaro was finally there....and then it was gone....so sad!
The Timken hubs (OEM supplier) wear out and the flanges are know to spontaneously fracture. Get the SKF race hubs at a minimum. They have a off-set double ball-bearing setup and the flange is much stronger.
MSI just posted up about a fancy new upright that can be used with a traditional hub w/ a spindle for racers who don't need wheel speed sensors etc. Might be right up your alley.
I know Mark at MSI very well, used a lot of his stuff mocking up the Camaro...hehe. I am just the test mule for Cortex's new uprights, and given my experience with them in the Camaro, I know they will be of superior quality...most likely better than the current offerings....at a minimum a push as far as performance "gain".
For my services, I will get them cheaper than I could buy any of the current offerings....
My question only pertains to running stock hubs in stock uprights for about 1 to 3 test days to get a baseline for Cortex to have. They will be using data aquisition to get their data. I just want to feel comfortable on the stock setup for 1-3 days.
I had a "bit of an off" my last time on the race track...hehe....
10-4... You should be fine on stock stuff to get a baseline for Cortex. If you want to be overly-**** you can check the hub flange for any evidence of stress fracturing periodically.
Usually on DOT-Rs i.e. V710, R6, A6, etc. etc. I've never had one go, but I have replaced one because I thought it was cracking. Forum member Oyishdog had his RF separate in T3 at VIR and I know Varkwso's son had his fracture in T10 at RA.
OEM hub failure on my T1 car back in my hpde days on R6's. Nearly a complete failure. I'm sure you will be fine for a couple days of testing. If you start to feel brake pad knock-back then take a look at your hubs. SKF hubs are great.
^ I ran my at VIR this weekend for the first time on SKF hubs in the front. I have Wilwood SL6R calipers (your old ones) and used to get some pretty good knock back going through the uphill esses. This weekend it was almost non existent even though I was taking that section of track entering at 132 and staying over 120 the entire way through.
