PS fluid cooked?
PS fluid cooked?
Haven't read much about this here and couldn't find any info in a search so....
Car is 2006 ls2 w/Z51 option. Driver is a beginner and have done a few DE/autoX. It seems like the PS fluid is getting cooked. At around 30K miles it looked like the original fluid was discolored and had a faint burnt odor - think trans fluid that got a little hot. I flushed the system and filled with new factory fluid - clear slightly pale purple color. Now after 15 K miles and only one AutoX, one DE the fluid is getting the color again and the burnt odor is slowly coming back. Anyone have this happen and what was the cure?
Autocrosses and road courses will do that. You may get away with using a synthetic PS fluid like Redline or Gibbs, but the ultimate cure is a Turn One power steering pump.
I will check the hose tonight. The real answer seems to be a different pump and not better cooling? I suppose this because the factory pump is overdriven at high rpm.
I had problems with the PS fluid boiling out of the pump. I changed the fluid to a synthetic and it solved the problem. That reminds me, I need to do that again.
Jim
Jim
OEM PS cooler + Redline fluid + sucking it out of the reservoir and replacing what was removed between track weekends = no PS issues for 10 years of tracking/racing C5s. Haven't needed a Turn One pump yet. However, if mine ever goes that's what I'd replace it with.
In addition to what travisnd posted, lower your fluid level until it barely touches the dipstick when cold. That will prevent if from boiling out past the cap if and when it gets hot.
