Brake bleeding question
Old 02-24-2012, 03:05 AM
Mike.D
Mike.D's Avatar
Default Brake bleeding question
When installing my headers, I tried removing this (see arrow in pic). It made a sucking sound like air was being sucked into the line so I immediately stopped. After the install, I stepped on the brake and the pedal felt sponge. Will a simple brake bleed fix this issue? Any thoughts would be helpful
Old 02-24-2012, 03:41 AM
trackboss
trackboss's Avatar
Don't worry about it. That is the vacuum booster. When you start your car all will be fine.
Old 02-24-2012, 04:00 AM
Mike.D
Mike.D's Avatar
thanks for the fast reply
Old 02-24-2012, 08:42 AM
CHJ In Virginia
CHJ In Virginia's Avatar
You did not open the brake hydraulic system so a bleed will not do any good. Make sure that the booster vacuum line is properly reinserted in the booster canister. Start the engine and run it at slightly above idle for 30 seconds or so to get vacuum back. Your pedal should firm right up.
Old 02-24-2012, 08:59 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
it is just a vacuum reservoir for the boost, it will recharge as soon as you start the car.
Old 02-24-2012, 06:20 PM
Mike.D
Mike.D's Avatar
Thanks again, its working fine!
To Brake bleeding question
Quick Reply: Brake bleeding question
