Torque spec for the F/R brake caliper bolts??
Old 02-25-2012, 01:37 PM
thatonedude1
thatonedude1's Avatar
Default Torque spec for the F/R brake caliper bolts??
Anybody have the Torque spec for the F/R brake caliper bolts?? Changing rotors and pads for march 10,11 HPDE. Thanks.
Mike.
Old 02-25-2012, 01:44 PM
longdaddy
longdaddy's Avatar
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
http://www.eliteengineeringusa.com/C6_Torque_Specs.pdf
print it, laminate it, keep it in your toolbox!
Old 02-25-2012, 03:58 PM
c4cruiser
c4cruiser's Avatar
Year of car?? There are variations in the torque values for the caliper abutment brackets based on the year. The C4's have two values based on the year.
Old 02-25-2012, 05:04 PM
Blackonblack89
Blackonblack89's Avatar
c5z i know is 125 and a tab of red locktie
it can be a pita to fit the tq wrench in there if the car is just barley jacked up. I had no leverage!!! On a lift it would be super easy.
Old 02-25-2012, 07:43 PM
thatonedude1
Default You get what you get
Finally done and washed up! Your right about the access. Depending on what wheel you're working on, it is difficult to get a long torque wrench into a position where you can push hard. It's pretty deep into the well. I used blue locktite and got about 110 ftlbs on them. I'm not 25 anymore and thats all I could push w/o tearing something. 110 ftlbs is a pretty tight though.
Thanks for the help guys.
BTW, I installed Centric Premium high carbon blank (no slots or holes) rotors and Carbotec XP10/XP8 pads.
Old 02-25-2012, 07:58 PM
rustyguns
rustyguns's Avatar
i put about 90 and alotta locktite never had one fall off yet!
Old 02-25-2012, 10:49 PM
sperkins
sperkins's Avatar
You can pop the tie rod loose to get better access to that bolt.
Old 02-26-2012, 03:45 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
I dont use locktight and just hit it with the wrench. Maybe you have the feel for the steel too. Ive never tq'd lug nuts either
To Torque spec for the F/R brake caliper bolts??
Quick Reply: Torque spec for the F/R brake caliper bolts??
