New oiling mods installed – thermostat, cooler, catch cans
I had some oiling issues last year (oil being sucked into t-body and dripping down past air filter).
So I hope these mods will alleviate that.
•Dual Catch Cans from CCA
•Oil Cooler (Thanks Randy @ DRM) race version with setrab 625
•Oil Cooler Thermostat – Mocal. 180 degree – Didn’t find many users here; some said it would not fit. No issues here.
[IMG]http://www.ponycars.net/images/z06/DSC_0281_511x768.jpg[/url]
Also just installed
•Turn One Power Steering Pump
•Joe Gibbs Power Steering Fluid
And got the car dyno’d (340 is pretty low for stock z06 but that is for a different thead).
Also just installed
Cruise-In II Veteran
I also installed the Mocal unit with the 180 degree bypass valve when I pieced together a engine oil cooler setup for my '02 Z06. I considered this essential as I drive this car on the street as well as on the track, and without the thermostatic function, its difficult to get the oil temperature up to an operational level during normal street driving.
You will be really happy with your set up
C5 Heads/Cam Swap - http://www.ls1howto.com/index.php?article=1
