F/S Lightweight Clutch Setup
Old 02-28-2012, 07:04 PM
geerookie
geerookie's Avatar
Default F/S Lightweight Clutch Setup
$$$$ SOLD $$$$
I'm selling my SPEC Lightweight clutch setup.
This came off an LS1 but should work on any LS motor.
This setup includes an
Aluminum Fidanza Flywheel,
SPEC Stage 1 Clutch Disc,
SPEC Aluminum lightweight pressure plate
The disc is .227 thick I don't know what they are new but it looks like there is plenty of life left
The friction surface on the flywheel is in good shape but a new one from Summit is only $62 Part Number: FIZ-221171
Everything worked great when removed. I also have a working used throwout bearing I'll throw in if you want it.
This setup new is $850 - $900
The factory setup weighs 57lbs and this setup weighs 31lbs. This is a huge reduction in rotating mass and make a noticeable difference in acceleration.
Selling for $375 shipped in the lower 48
Old 02-28-2012, 11:41 PM
sperkins
sperkins's Avatar
Bump for a good deal. I paid well over a grand for mine 2 years ago.
Quick Reply: F/S Lightweight Clutch Setup
