New Road Race motor fresh off the dyno
Old 03-06-2012, 07:57 PM
bosco022
bosco022's Avatar
Default New Road Race motor fresh off the dyno
Recently had our new 383 LS6 on the dyno: 570 hp 477 torque on a known conservative engine dyno
* Schwanke short block about 11 to 1
* Advanced Induction full cnc ported 243's
* .612 lift cam
* GMPP 4 bbl manifold
* Holley HP 4150 750 cfm
* Schoenfeld headers
* stock l92 pressure oil pump with barnes scavenge dry sump pump
Will replace the 480 hp LS1 in our Howe/Bemco Camaro for the Crane Cams V8 StockCar Series
Old 03-06-2012, 08:29 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Those sound like solid numbers! Now all we need is a video!
Old 03-06-2012, 08:51 PM
trackboss
trackboss's Avatar
at what rpm are those numbers? Sounds like a strong motor.
Old 03-06-2012, 09:02 PM
bosco022
bosco022's Avatar
Max power: 6800 and still climbing
Max Torque: 5500
The rev limit was set at 6900, Byron Koury, the engine builder who did final assembly and dyno stated he thought it would continue to make HP for another 400-500 rpm. He said he would guess another 10 HP.
Gonna leave it at 6900 for reliability.
Old 03-06-2012, 09:19 PM
C5ZEE06
C5ZEE06's Avatar
those are good numbers for a 383. what would you guess the numbers will be at the wheels ?
Old 03-06-2012, 09:33 PM
bosco022
bosco022's Avatar
This is our first 383 and I am pleased. I think the Advanced Induction heads were key, plus a nice road race cam in a good, cost effective short block from Schwanke.
Byron Koury also stated that the Holley 750 carb by Crandall Sizemore of the Spirit of Daytona DP Corvette team is a very fine one.
I have never had one of our race cars on a rear wheel dyno, but I'll make a guesstimate and say 510 ish ???
To New Road Race motor fresh off the dyno
Quick Reply: New Road Race motor fresh off the dyno
