2nd time homestead!!
Had a blast today at my second event ever at homestead...a couple of things from this time around:
-I wasn't as aggressive this time for some reason but I was stayin far more consistent and hitting the lines way better
-unfortunately I went off track on that pesky turn 10 ...I knew exactly what happened and what I did wrong...turned in too early, didn't slow down enough (although the instructor says the speed was fine)...and I let off the gas in the turn...I felt the car go squirrely and knew I wasn't going to make the turn sooooo I just did what they teach, go straight into the grass...nothing happened to the c6 that I could visually see...
-after a full day and as odd as it may sound cause of my mishap into the grass, I was allowed to go I to the solo group!!
Only things I've changed since my first track day at homestead was the brake pads and brake fluid...had a blast and will be going back tomorrow morning for the second dy of sessions, solo!!
Have two of my 5 sessions on film and will upload when I get a chance, given that they look decent as it was my first time using the gopro...
The more I run Homestead the better I like it. I love coming off the front straight and making the left turn into the road course - without touching the brakes.
I'll never get the toilet bowl right - and I've tried. A lot.
I also love the perfect pavement. Then again after Sebring every piece of pavement seems perfect.
Who are you running with?
Richard Newton
Richard Newton
Richard Newton
Richard Newton
NASA is running there this weekend.
Richard Newton
Richard Newton
running with nasa this weekend...my first event was with hooked on driving back in early december...
Track Junky
Good stuff. You got that coolant temp thing worked out?
I lost my LS2 last weekend at Homestead due to a timing chain break and looking for options on the rebuild now... torn between LS3 dry sump or rebuilding my LS2 with forged internals and aftermarket dry sump. Second option could get REALLY expensive if I'm not careful.
What times were you running? Still low 1:50's?
damn, second option can definitely get expensive man lol...how quickly are you looking to make a decision?
aahh so i used harrys lap timer...my fastest lap was 1:49.63
and it was with the instructor in my car...so since i graduated to solo, i did one session alone yesterday and 2 today...on the third one i asked for my instructor from yesterday to ride along with me so that he can see where im losing some time (up to that point, the best time was 1:52.6x...so he rode with me a couple laps, pointed out my braking points on two corners...and then on the third or so lap, BAM....1:49.63...friggin ecstatic about it ...im downloading the video to my laptop from the gopro camera so i can post it up...not sure if i can overlay the harrys laptimer on it as well...would be cool if so...
Track Junky
Great times for your second time in the track!
I will have the engine out of the car next week, hoping to make a decision the week after that depending on how the block looks. I got down to 1:47 on my heat cycled PS2's before the engine went. I think I could have squeezed another second out of myself and the car if I ran the last 2 sessions. Defiantly time for some R-compounds or Hoosiers after the build is done. I can easily out drive the tires I have now.
Congrats and great driving. I wasn't in the 1:40's until my 4th day out there.
Damn I'm jealous of your 1:47 time lol...seemed like impossible to get into the 1:40 range...I was ecstatic that I hit 1:52 ...what else have you done to your car?...I'm "trying" to stay as close to stock as possible (I assume changing brake fluid and pads doesn't constitute a "true" mod?)...
If you remember meeting them, the guy with the 135i is doing mid 1:40's...the guy with the z06 is on the same boat...so I guess relatively speaking you and I aren't doin too bad
Thanks for the congrats!!...dude im psyched and wanna head out again lol...only difference from 1:52 to 1:49 was the braking distance...changed that up per the instructor and voila
