relay on pass. side floor? in the way of hardbar rail
Old 03-11-2012, 11:10 AM
2MCHPWR
2MCHPWR's Avatar
Default relay on pass. side floor? in the way of hardbar rail
hey guys - what is the relay on the floor on the passenger side? its in the way of where I have to put the hardbar rails.
i unplugged it and got traction control error.
can i relocate it somewhere? Besides having 2 small bolts, i think its glued on the floor too. I don't want to pry it up before knowing what to do with it after i pull it up and making sure i won't damage it.
thanks!
Old 03-11-2012, 11:14 AM
2MCHPWR
2MCHPWR's Avatar
Lateral Accelerometer: The lateral acceleration sensor measures the centrifugal force created in a turn. The data it provides is weighed against all of the other inputs and is used to calculate whether or not the car's limits are being exceeded for the speed and traction conditions that exist. This sensor is located beneath the passenger seat.
ok - can i remove/relocate it?
Old 03-11-2012, 11:27 AM
2MCHPWR
2MCHPWR's Avatar
got it:
http://forums.corvetteforum.com/auto...-question.html
Old 03-11-2012, 06:19 PM
gmccreary
gmccreary's Avatar
If your car is a C5Z you will need it for the traction control. I pried mine up and mounted it on top of the Hardbar rail. I drilled two holes in the bottom of the rail, countersunk and used bolts and nuts to attach
Old 03-11-2012, 06:25 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
the last rails I installed had holes pre-drilled for it, but you would need to lengthen the wires.
Old 03-11-2012, 07:23 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Hardbar rails have predrilled holes to mount to.
Old 03-11-2012, 08:44 PM
PA Z06
PA Z06's Avatar
Same here but I had to make the holes a little bigger and thankfully I didnt have to lengthen the wire, it just fit
Old 03-27-2012, 09:36 AM
2MCHPWR
2MCHPWR's Avatar
got it. thanks guys.
To relay on pass. side floor? in the way of hardbar rail
Quick Reply: relay on pass. side floor? in the way of hardbar rail
