Schwanke built LS1 long block (706 heads) $800
Old 03-21-2012, 07:48 AM
bosco022
bosco022's Avatar
Default Schwanke built LS1 long block (706 heads) $800
Schwanke built LS1 long block (706 truck heads)...... minus cam.
has GM crank and rods with Mahle forged pistons
706 truck heads made for almost 11 to 1 compression with excellent torque
pulled so hard between 3000-6500 it was unnecessary to rev past 6500, and didn't like it anyway.
was very reliable and won many races and set a daytona track record
nothing fancy, but ran extremely strong making over 480 HP with nearly that much torque utilizing a 580 lift cam
I think a good buy for the home engine builder.
This motor in our Howe/Bemco chassis stock car ran 1:30 at Road Atlanta, 2:16.xxx at Sebring and 1:57 at Daytona
This motor was not hurt, but was replaced with a new, more powerful Schwanke LS6.
$ 750
Moroso ASA dry sump pan and Razor single stage scavenge pump for 450 bucks more
contact Bosco @ 386.717.0745
bosco022022 at yahoo dot com
Old 03-21-2012, 02:23 PM
bosco022
bosco022's Avatar
also have another set of LS1 853 heads that can go with no extra
Old 05-24-2012, 12:14 PM
bosco022
bosco022's Avatar
new price $ 750 for engine
$ 450 for Razor single stage scaveng pump and Moroso LS1 dry sump pan
Old 05-24-2012, 12:24 PM
AU N EGL
AU N EGL's Avatar
Bosco
Post this over in the C5 Tech section too for more exposure.
Good Luck
Tom
Old 05-24-2012, 12:43 PM
athornt2
athornt2's Avatar
pm sent
To Schwanke built LS1 long block (706 heads) $800
Quick Reply: Schwanke built LS1 long block (706 heads) $800
