Autocross Tire Size Help!
Old 03-29-2012, 11:20 AM
justink
justink's Avatar
Default Autocross Tire Size Help!
Im going to be ordering either Hoosier A6 or Kumho V710 autocross tires for the upcoming season. Need some help on tire sizes and any opinion on the two brands. Ill be running a 2003 z06 with stock rims,
17x9.5 up front and 18x10.5 in the back. For the Kumho i was thinking 275/40 for the front and 315/35 or 305/30 for the rear. For the Hoosier 275/40 for the front and 295/30 or 295/40 for the rear. Hoosier also has a 315/30 but their tire guide asks a minimum 11" wide rim.
Old 03-29-2012, 11:35 AM
dgoetz
dgoetz's Avatar
The most popular sizes for A6's in autocross for C5 ZO6 are frt 295/35x17 and rear 315/30x18 on stk size rims for SS class
Old 03-29-2012, 11:43 AM
froggy47
froggy47's Avatar
Old 03-29-2012, 01:09 PM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
+2 on that.
If you go haven't upgraded your front bar on the car, the 275s will work better. If you HAVE the bigger bar, the 295 will work great. My car with a big bar doesn't like the 275 up front. Can't speak of the Khumos, but the Hoosiers work great and with good camber they last allot longer than you think.
Old 03-29-2012, 01:43 PM
justink
justink's Avatar
Thanks guys!
Old 03-29-2012, 01:46 PM
justink
justink's Avatar
Originally Posted by AverageVetteNut
+2 on that.
Im having the car alingend soon. I have the manufacturers numbers, any advice on the setup numbers?
Old 03-29-2012, 01:56 PM
froggy47
froggy47's Avatar
Pfadt and Vette Brakes & products both have very good guidlines. Search on those.
Old 03-29-2012, 03:02 PM
AverageVetteNut
It all depends on how much street driving you're going to be doing and how far between your place and the events.
Mine spent most of the year on a trailer, so I went full tilt on mine based on recommendations.
This year it will be more civil to save tires on the street since I'm driving it there.
Old 03-29-2012, 03:12 PM
justink
justink's Avatar
The care is going to be strictly trailored so im going to want as aggresive as can be
Old 03-29-2012, 04:29 PM
Grabbed_Crow_Mobe
Grabbed_Crow_Mobe's Avatar
This is what I have used and have had good results:
http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
Old 03-29-2012, 07:58 PM
acrace
acrace's Avatar
http://forums.corvetteforum.com/auto...alignment.html
Re alignment: my thoughts are in post #10 and #11 in the above link.
To Autocross Tire Size Help!
Quick Reply: Autocross Tire Size Help!
