Ls3 camshaft for a C5 that autox's
I have a C5 Z06 that has a LS3 swapped in. the engine has a Vengeance racing stage 3 cam ( 231/243/ .616/.624/ 115+3). The car is not drag raced it is my SSM Autox ride. This cam is causing a surge and has a sizable jump in power at 4k rpm. this make the car difficult to autox as the power hit mid corner. I am thinking of swapping out the cam to something that will smooth out the power band. I was thinking something ing the 224 range. Anyone have any suggestions? I am willing to lose some peak #'s to gain under the curve.
stock cubes? the L92 heads do not need a big cam, its not like the cathedrial heads. I have an LS3 to a 416 and mines only a 232/246. If its for road racing/ autocross, id lower the lift as well
Bsalie, that is a good size cam but more importantly how well is the car tuned? I would guess that a smaller cam might be a bit more appropriate for the task but I think making sure it is tuned well will go a long way to helping it be a bit more autox friendly. What else is done to the LS3? Stock heads/intake/throttle body, etc? Also what gears are in the car? I am good friends with the GM tuner at a local shop who also owns an heads/cam LS3 Camaro. His cam is not as big but the car's street manners are excellent.
The car is very well tuned. That did cure a ton of its bad manners. It has the stock gears and the MN12 tranny which are perfect for autoxing. we are just trying to make it have a smooth power curve when it drop low in the rpm range.
The car is fun on the street, but could be faster on the autox
Premium Supporting Vendor
CMC-20 Camshaft
21st Century Muscle Cars CMC-20 LS3, L99 camshaft will produce excellent broad RPM power gains and has a moderate musclecar "lope" It is suitable for six speed manual transmission equipped vehicles as well as six speed automatic transmissions cars
Suggested in LS3-L99 applications
Camshaft specifications: 223/235 duration @ .050 .610/.620 with 1.7 ratio rocker arms 115.0 CL.
Best Regards,
John Page
Twenty First Century Muscle Cars
972-417-7177
