Are C6 Rotors Interchangable With C5 Rotors?
Old 04-05-2012, 08:12 PM
Sidney004
Sidney004's Avatar
Default Are C6 Rotors Interchangable With C5 Rotors?
And the answer is.....
Old 04-05-2012, 08:38 PM
argonaut
argonaut's Avatar
Base C6 -yes (12.75"). Z51 C6 -no (13.4") unless you use the caliper mounting brakets from the C6. Z06 C6 - no (14")
Old 04-05-2012, 08:56 PM
doje
Support Corvetteforum!
doje's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
More detailed:
Base C6 - yes (12.75").
Z51 C6 - no (13.4") unless you use the caliper mounting brackets from the Z51 C6.
Z06 C6 - no (14")
By going to either the Z51 or Z06 upgrade, you will need to upgrade to a minimum 18" front wheel. Also, in the case of the Z06 brakes, you will need to make sure your wheel spokes also clear the brakes.
Old 04-05-2012, 09:19 PM
Sidney004
Sidney004's Avatar
Great, Thanks!
To Are C6 Rotors Interchangable With C5 Rotors?
Quick Reply: Are C6 Rotors Interchangable With C5 Rotors?
