C6 owners - name this transaxle part please
4th Gear
[I was directed here by a friend, I was told the AutoX guys on Corvette forums were knowledgeable]
I'm working on a C6 that hit a crub and sheared the transaxle mount.
I can't find what this piece is called, so I can't buy a new one.
The piece in question is the single-piece aluminium bit that the CV goes through and the transaxle mount bolts to.
Can anyone help me out? Thanks.
It's this piece on the passenger side ^^
the diagram calls it: Cover,diff carr (assuming youre referring to #s 2 and 3)
POS__Part#_______Model/RPO____Name__________
002 19132920 Y(LS7, MM6) COVER,DIFF CARR(W/RR AXL BUSHING)
002 19132926 Y07-67(LS2, MYC, KNR) COVER,DIFF CARR(W/RR AXL BUSHING)
002 19132929 Y07-67(LS2, MYC)(EXC KNR) COVER,DIFF CARR(W/RR AXL BUSHING)
002 19132930 Y07-67(LS2, GU6, MM6, MZ6)(EXC KNR) COVER,DIFF CARR(W/RR AXL BUSHING)
002 19132931 Y07-67(LS2, GU6, MM6, MZ6, KNR) COVER,DIFF CARR(W/RR AXL BUSHING)
002 89060111 Y(LS7, MM6) COVER,DIFF CARR(W/O BUSHING)
002 89060169 Y07-67(LS2, MYC)(EXC KNR) COVER,DIFF CARR(W/O BUSHING)
002 89060170 YY07-67(LS2, MYC, KNR) COVER,DIFF CARR(W/O BUSHING)
002 89060171 Y07-67(LS2, MM6, MZ6)(EXC KNR) COVER,DIFF CARR(W/O BUSHING)
002 89060172 Y07-67(LS2, MM6, MZ6, KNR) COVER,DIFF CARR(W/O BUSHING)
003 19133199 YY87(LS7, MM6) COVER,DIFF CARR
003 89060173 Y07-67(LS2, MYC) COVER,DIFF CARR
003 89060174 Y07-67(LS2, GU6, MM6, MZ6) COVER,DIFF CARR
Always check for the newest part numbers
you can use this site to cross reference newer numbers http://www.partstaxi.com or http://www.gmpartshouse.com/
they both have the cheapest pricing and the staff are quite knowledgeable. Rather than order online, I would definitely call in to make sure youre getting the right parts
hope this helps
EDIT:
One more diagram - from parts taxi(obviously the numbers listed above will not apply to this diagram)
hope this helps
EDIT:
4th Gear
Awesome, thanks.
Did some searching for that term and found this:
http://www.vetteweb.com/tech/vemp_08.../photo_13.html
That's the part I need, but they don't say what it is or give a part number.
*edit* They call them 'outer covers' in that write-up
Know of anywhere to get that second hand?
