Front rim slightly bent...issue for HPDE?
I've got 18x8.5 repros of the 09 z spyder wheels up front. One has a slight bend where I must have hit something last summer. I can feel the vibration when I drive but it's not enough to really bother me. I'm pretty sure it was there before I did my first HPDE last year. Is it something I need to go get addressed before my next track days or is it a negligible issue?
At a bare minimum, get the wheel rebalanced.
Personally I wouldn't feel comfortable with a bent rim on the track. Hit something wrong loose the seal between tire and wheel and you could be in a bad spot. If it happens when you are near other cars the situation just got a lot worse.
I think it's enough of an issue for you to have it fixed. Last year, 3 days before an event, I found when having a tire mounted that 1 rim was bent enough that he couldn't get a good balance. I managed to have this rim fixed on a weekend locally.
It depends on how and where it is bent? If if can be balanced and there is no vibration and the tire holds air and the bead seals properly??? Then it may be OK? Have it checked by a good wheel shop and they should be able to tell you. Impossible to say without seeing the wheel. I have a bent CCW that I had checked by them and it works fine. JD
It depends on how and where it is bent? If if can be balanced and there is no vibration and the tire holds air and the bead seals properly??? Then it may be OK? Have it checked be a good wheel shop and they should be able to tell you. Impossible to say without seeing the wheel. I have a bent CCW that I had checked by them and it works fine. JD
DH
I know that all repro wheels aren't of the same quality but I have seen two C6 repros break completely off the car at DEs. I have never seen the same from an OE wheel. I don't recall if the car had street tires or not. I know there are a ton of other factors that could have led up to the failure.
What's my point?
IMHO a repro wheel is risky at a DE, a bent one is a definite NO.
What's my point?
What's my point?
What's my point?
THANKS!
