got some coil overs spec'd from LG. thoughts?
Old 04-15-2012, 08:55 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default got some coil overs spec'd from LG. thoughts?
So i talked to LG about my set up and what i was doing with the car. They told me to run the G2 coil with the short shock body and 700 on each corner
3200lbs with me in it
Undertray, 4" splitter
68" wing
1" lower than stock
Dba rotors, pfc01 pads, stock caliper
18s on each corner. 265, 305s
Car sees 70% street 30% track.
Thoughts?
Old 04-15-2012, 09:45 AM
GettReal
GettReal's Avatar
68" wing
1" lower than stock
Thoughts?
I would trust LG with their suggestion so not sure what you are questioning, but have you considered going with a double or triple adjustable set up?
Old 04-15-2012, 10:46 AM
Falcon
Falcon's Avatar
Coming to us for advice, after LG told you what you needed, is like going to the bait shop for medical advice after the heart surgeon recommended open heart surgery.
Old 04-15-2012, 12:47 PM
VGLNTE1
VGLNTE1's Avatar
yes I understand that, but with everyone here there is decades of experience and I do listen to advice I get in here. Im not saying LG is wrong, just curious on the thoughts is all :-)
Old 04-15-2012, 05:48 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
Go with 'em! You won't be sorry!
Jim
Old 04-15-2012, 11:05 PM
mountainbiker2
mountainbiker2's Avatar
What is your current setup?
Old 04-15-2012, 11:35 PM
froggy47
froggy47's Avatar
Why the little tires?
Old 04-15-2012, 11:55 PM
redtopz
redtopz's Avatar
Sounds good to me. Are they going to valve the rear shocks to match the 700 lb springs? I'm running the standard 700/600 G2 coilovers with full aero and the rear is a little soft, but it works well. I would also run larger tires such as 315 square.
Old 04-16-2012, 06:03 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
68" wing
1" lower than stock
Thoughts?
who here knows more?
Old 04-16-2012, 07:34 AM
VGLNTE1
VGLNTE1's Avatar
275, 315 track tires
Old 04-16-2012, 07:35 AM
VGLNTE1
VGLNTE1's Avatar
Maybe this is why they told me 700 on each corner. I run a 315 track tire. 305 is on the street
Old 04-16-2012, 09:08 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Go with their suggestion. I've been using the LG coil overs and have been very happy with them!
To got some coil overs spec'd from LG. thoughts?
Quick Reply: got some coil overs spec'd from LG. thoughts?
