What valve springs to buy, LS6 with cam?
Old 04-17-2012, 10:40 AM
stevensa
stevensa's Avatar
Default What valve springs to buy, LS6 with cam?
Hey guys,
In the coming months I am going to be doing some preventative maintenance on my car (02 Z06 with LS6). The car has a cam, however I have no idea what kind it is as the previous owner installed it and the place I purchased the car from didn't know anything about it. I would guess it is pretty average as the car only has the cam, longtubes, no cats, and a vararam and made 400whp/375wtq on a mustang dyno.
So, what type of valve springs do you recommend for the car? I am not sure what kind are on the car now, for all I know they could still be the stock springs. Is there a good all around spring that everyone tends to run for average setups like mine?
I plan to pull the valve covers and see what is in there now before I buy anything, and I am actually probably going to pull the cam out too so that I know what is in there. I am sure there will be a thread in the future with more specific questions pertaining to my actual cam, but for now I was hoping to find out about some good all around valve springs to run.
Thanks,
Andy
Old 04-17-2012, 10:47 AM
Bad Karma
Bad Karma's Avatar
I would pull the valve cover and see if you have factory springs. If the previous owner installed the proper springs with the cam I wouldn't so worried, but factory springs I would get out of there.
If you have a dial micrometer or access to one, you can check cam lift at the valve spring and order new springs accordingly.
Old 04-17-2012, 11:02 AM
stevensa
stevensa's Avatar
Good idea. I am mainly going to replace the springs because I have had the car for 3 years now and have been tracking it pretty regularly since I bought it. I also dont know how long they have been in there, and what the previous owner did with the car. I figured it would just be good maintenance to do.
Old 04-17-2012, 11:34 AM
LSOHOLIC
LSOHOLIC's Avatar
http://www.yellowbullet.com/forum/sh...d.php?t=454316
the best springs on the market and one hell of a knowledgable and nice guy also. And also super affortable.....
thanks.....
Old 04-17-2012, 01:50 PM
AVB
AVB's Avatar
Heard good things about PAC springs
To What valve springs to buy, LS6 with cam?
Quick Reply: What valve springs to buy, LS6 with cam?
