need tires for occasional track events
I already have the Michelin PS2s on after market rims but I'm looking for something to put on my original split spoke chromes on my 2009 Z06to run at the track 5-6 times a year. I'd like not to have to change sizes. Can anyone recommend anything to me?
I found Nitto Invos and not much else. I also found someone saying the soft sidewall wasn't great at the track.
Thank you all.
Thank you all.
I would run scrubs (slicks) from Forum vendor GT Tires. They advertise here on this RR/Autocross board. Save your street tires for the street.
Supporting Vendor
Call me anytime. We have a few options for you. We are expecting another truck load next week. I will be posting new inventory then, Our current inventory is over 1000 tires in various brands and sizes/
Todd
414-350-6303
Todd
414-350-6303
Another vote for GT Tires. Great guys and great service, will be calling again when I wear out my current set of scrubs/slicks.
The NT05's are great in dry weather but can get very slippery on wet surfaces. When I finally wear mine out I plan to go back to something more "rain friendly"
Did you buy 285/35/18 for the fronts when you bought the 335/30/19 for the rears? Someone mentioned throwing codes if you went with the 275/35/18 on the fronts.
I have read this elsewhere but I would only use them in dry weather to, from and at the track. Thanks very much for your input and advice. I did contact GT Tires and am awaiting the reply.
You can run "Square" setup on tires, IF you turn off all the nannies. OR you can run slightly taller rear tires (0.5") and run everything "on". This is MUCH cheaper than ruining expensive street tires. PS get the suggested starting pressure for the slicks, and altho it will seem VERY low, please FOLLOW the directions for slick tire pressure!!! (and WARM em up)
Thank you all for your valuable input.
