Need to reinforce front splitter
All,
On my C6 Z06 I have the Katech front splitter, complete with the front facing brake ducts and undertray. This setup generates a lot of downforce, but the problem is that it generates TOO MUCH downforce for the standard flexy front bumper. Even with the ZR1 bumper reinforcement, this setup has ripped itself off my car not once, but twice. Both times happened around 140 MPH on the track. Anyway, instead of just getting it to rip off a 3rd time, I had a custom 3 rod support made for the splitter which seemed to finally keep the thing in place, but it was really pricey and now that I've destroyed the front splitter in a sandtrap, I'm not looking on paying $4k again to have it reinstalled. So I'm wondering, has anyone else had to reinforce their front splitter using rods and heim joints, and if so, how did you do it? Any plans or lessons learned would be appreciated. I know I can't be the only one who's had this problem, especially you ST1 guys must have learned how to deal with this stuff!
Do you have any pictures of the setup you purchased? $4k sounds quite steep. I like making stuff in my garage, I haven't seen a C6 splitter set up, but $4k, wow.
You can get the splitter supports you need from LongAcre. Then remove your front bumper and weld or bolt in some angle iron supports to anchor the tops of the support rods. Drill a hole through your bumper and bolt them up. Probably $100-200 and you'll be good to go. You might need to do something similar for your undertray if you have one. This is how my front splitter is supported.
These threads might be of interest:
http://forums.corvetteforum.com/auto...ng-fascia.html
http://forums.corvetteforum.com/auto...-splitter.html
H
Here is what we made and installed. It adds about 5#. It costs about $300 with professional welding.
Jim
Jim
I have a LG splitter that came with the small undertray. Besides the ZR1 bumper reinforcement, I had Boos Performance in Minnesota fab a bracket. They bolted a small piece of angle aluminum to the front cross member with the bumper removed. Then ran a small piece of flat aluminum (1/8" x 1")from that bracket down to inside level of the splitter undertray. Then attached a piece of aluminum plate to that bracket. Reinstalled the bumper and splitter and used rivets to attach the undertray to the aluminum plate which resides on the top side of the undertray. About a 5 or so hour job, all hidden inside the bumper and just a few bucks worth of aluminum. The result is that the undertray of the splitter is directly attached to the front cross member.
Anyway, lots of good suggestions here on how to get this part to actually work on the track, it's just a shame it didn't come this way from the factory, and that I had to destroy two of them at the track before anyone would believe that there was a problem. Bill, I'll look into the Longacre splitter supports, I've always had a good experience with those guys.
BTW here's my video of the splitter failing at 144 MPH:
http://www.youtube.com/watch?v=U8Su-E9aWPU
And here's a nice pic of what it looked like right before it ripped itself to bits:
And here's what it looked like at the end of the day:
Not exactly the safest day I've had at the track!
Before you go and do the samething again look at this link. If you truly looking for track quality stuff....
http://forums.corvetteforum.com/auto...areo-mods.html
I would say that they all would, under the right circumstances. The problem is not many Z06/ZR1's regularly hit 150 MPH. Around 140-150 is where things start to be a problem... and from what I've been reading I'm not the only one that's had this problem.
Premium Supporting Vendor
Interesting. I see I am not the only one who's had this problem. But of course on the phone I was told that I was the only one that was having issues.
Something is wrong here. The front grille should not be flexing that much with the front fascia reinforcement installed. We've been much faster than that with the combination and it doesn't do that. What reinforcement are you using? If the splitter was ripped off once before it could have damaged components and caused the second one to not have a firm foundation to mount on to. Can you get it into Katech so we can take a look at it?
It was the GM front fascia reinforcement used on the ZR1. After taking it apart, we found that the front fascia has been broken from the stress of the downforce. Do they make a stronger one? I was running a lowered car at the track, so the splitter was probably generating more downforce than you might expect. But I don't think reinforcing the bumper is the way to go, because you will still have to deal with the entire bumper pulling down from the car. The way to go is to have a few of those metal rods with the heim joints that you see on other cars... do you have a kit with these parts? I was just going to fab up some supports myself, but if you have something that's that's already figured out, let me know.
i think there is a market for this so make up some kits for a reasonable price and good install documentation and i would be interested, i can tell my front bumper is starting to sag from front splitter stress as well.
What about just fixing the root of the problem and make a stronger front fascia out of carbon fiber that is reinforced in critical areas?
