When are my brake pads done?
Hey guys, looking for a gauge on my brake pads, I have been working on trying to get my budget under control, while affordding more track days. with that being said, I am currntly running DBA 4000 rotors, Quantum Cooling kit and CarboTech pads xp-8/XP-8. I currently have about 12/30 min sessions, 4 at Sebring and 8 at daytona, I have been told my rotors appear to have about 1-2 days left and I am looking for your input on minimum thicknes on my front pads, I was hopping to get one more day out of them. I am going to XP12/XP10 when these are done.
I change pads at 50% pad thickness, then keep for emergencies
50% pad thickness does NOT mean 50% pad life remaining, more like 20% pad life.
As to your rotor life, run them until the cracked to the edges.
I usually run my pads down to 1/8 to 3/16" before trashing them. If they are close, I just replace them as I hate thrashing the brakes while hot at the track. Rotors, I run them till I get a heat check crack big enough to catch a fingernail in. If it hangs in the crack, they are replaced. Same thing, I hate changing hot rotors at the track between run sessions.
Yes, I do my own brakes, and general work, I used to build my own motors but those days are gone , Soooo I should be able to get through 4-5/30 min sessions on 1/8 left ? ,...I will be taking my spares (Rotors, pads) but don't really want to have to change them at the track. I drag raced in my younger days and have not raced for 15 years until I bought my z06 eight months ago and now have 8 track days. I will say this there is no comparison Tracking to Drag racing I am having a blast.
I understand your budget concerns; brakes are a major wear/expense item.
Jim
These are the pictures of my rotors, I sent these to Ken at KNS and to Steve at DBA they both said the same thing run until your finger nail catches. "as a general rule". I will say Ken is great always willing to talk and educate.
Thanks, I have XP12's coming, so I think I will take your advice and just change them out, I have Michelin PSS in stock size, I ran these at Daytona, and i have a set of NT05's 285/335 I have been using as my track tires, just now on my second set. Hind sight, wish I would have bought R6's.
In my '03 Z, I generally run them down until the friction material is as thick as the backing plate, no special tools required or guessing. Not sure this applies to a c6 z, I also run Ti shims past 50% pad thickness to help insulate the caliper pistons a bit. Not sure anyone makes shims for the C6Z setup... Padlets or not.
The reason I ask is that since rotors and pads are consumable items it saves a lot of money that can be put to better uses. With the cheap NAPA rotors I run them till they crack and then change them. I agree that working at the track can be a PITA but sometimes you just have to do it.
Yea, I hear ya, in my drag racing days that’s all I did was work, work and work. I took my NT05's to Daytona and decided to run them on day two, they were vibrating around 140 so I came back in and took them off and had Hoosier balance, put em back on and again same thing. not sure if it was really a problem as much as the Michelins were smooth as glass, anyway back off they came and back on went the Michelins. as my wife was questioning why I was working so hard, the guy next to makes a commit did you come here to work or to have fun. Ha
Jim
