DIY for changing Antifreeze to H2O w/ WatterWetter
Any DIY's available for changing the coolant? Tips, hints?? Anything? If I just drain from the bottom of the radiator, does this empty the block? How do I empty the reservoir?
Jim
Jim
My suggestion is cycle out the old coolant with multiple flushes. Drain, fill with water, run the car with the heater on, drain and refill and repeat. Probably 30 mins of this should have the drain "product" clear water. Once you see that, add in your final "fill" be it straight water or distilled leaving enough room for one or two bottles of Water Wetter. I do change out my radiator water regularly when not running coolant.
i just drain it once and then add 2 bottles of water wetter and fill it up with water.
seems to work really well ! temps dropped 15 degrees! and when hot it drops fast when you short shift i change it once a year
Jim
Thanks Rusty,
I'm probably going to have to go back to antifreeze after track season so this will be a complete do-over every year.
Dang, that Royal Purple Water Wetter is expensive- $16/bottle!
Jim
Just finished this project on my '87 for the upcoming track season. I wound up doing a total of 5 flushes to get nearly all of the old coolant out. Drain radiator, refill with water, start engine and run to 180 degrees, drain and repeat.
Don't forget to drain and clean out the coolant overflow container. Refill it with plain distilled water after the final refilling of the system.
I used distilled water for the flush cycles as it was on sale at a local grocery store for $.89 per gallon. For the final fill with distilled water, I added a bottle of Red Line Water Wetter.
Our county has a hazardous materials disposal place at the landfill and they take oils, oil filters, and coolants at no charge. Many auto repair shops recycle old coolant so it might be worth calling a few to see if they will take coolant.
Good question. The first drain of antifreeze I stored, it was almost new and will be reused. I live in California and have had conversations with the city's "hazmat" team. They suggested I take the diluted drain flushes and pour it down the sink drain. Yeah, I know it sounds terrible but they told me it will get cleaned up by water treatment before it hits the ocean. Any other non-captured method is a problem as it will either migrate into the water table or drain to the ocean. I had planned to take it to our city's hazmat collection site but after talking to the hazmat team I followed their advice.
Thanks for the help guys!
Jim
When you drain the radiator via the petcock the reservoir will drain as well. You will have some left in the heater circuit and the block. Fill the system with plain water, follow the OEM bleed procedure and then run the car for a bit with the heater on to cycle that through. Then drain it again. After that just fill it with distilled water (available cheap by the gallon at Wally World) and a couple bottles of water wetter and then follow the OEM bleed procedure.
As for disposing... to be honest I just mix it in the big drums I keep my other fluids in and take them to the local recycling center. Probably not supposed to do it that way.
Thanks,
Jim
Safety. I've usually been OK with the water temps except of one time at Rd. Atl. when it was over 100*F. Short shifting on the back straight got it under control. Now I have the DeWitts radiator, I expect no issues at all.
See ya next weekend at VIR.
Jim
Jim
1. Fill the system through the reservoir to the full line.
2. Start the car with the cap off and let it idle for 1 minute.
3. Put the cap on and run the car varying between idle and 3000 rpms for 30 second intervals. I.e. 30 seconds idle, 30 seconds 3000 rpms, 30 seconds idle, and so on. You do this until the coolant temp gets high enough for the t-stat to open. On a C5 the OEM t-stat is 192 degrees (or maybe 194?). If you have a lower temp one then you do it until you get over whatever temp. You can go feel the radiator hose coming off the water pump to see if the t-stat has opened or not.
4. Turn the car off and slowly remove the reservoir cap letting the pressure dissipate. It won't be hot enough to spew anywhere.
5. Leaving the cap off, go turn the car on and let it idle for one minute.
6. See step 3... repeat the cycle a few times (the manual says 3).
7. Add water as necessary. Once you're done and the car has cooled, verify the water is at the COLD FULL line on the reservior.
Well, that certainly was a time consuming project! I can see why few HPDE people would do it. In a C6Z w/ my new DeWitt radiator, I was only getting about 1-1/2 gallons of fluid out per flush. After four flushes, I still had a trace of antifreeze in the water. The last flush was with distilled water then I refilled with more distilled water.
Thanks fore you help everybody!
Jim
Jim
