FS NASA ST2 Car
FS NASA ST2 Car
For Sale:
ST2 racecar built from a 1998 Corvette Coupe built by Phoenix Performance and maintained by owner and Tick Performance. Currently races in NASA ST2 and classed for TTS in NASA Time Trials. Built from a clear titled car and never damaged street car with 60k miles.
Body/Frame/Cage:
1998 original body panels, except for nose cap; clear titled car
Original frame, never bent, crashed, or damaged
Ecklers ACP style nose
ACP 4 front splitter with custom made under tray
Kognition Racing carbon fiber wing with custom made uprights directly attached to the frame rails
Full cage built by Phoenix Performance to exceed SCCA T1 and NASA regulations; custom painted to match exterior color of car
Brand new front windshield
Safety:
Full in-car fire suppression with 3 nozzles and substantial driver coverage
Separate fire bottle under hood with auto activation
FIA drivers harness good through 2012
New drivers window net
Kirkey deluxe aluminum drivers seat with required head restraint; Hardbar seat mounting system
Master cutoff switch
NASA logbook
Engine/Drivetrain:
Last refresh Fall 2010 by Tick Performance
Tuned for 93 pump by PCMforLess
LS1 block
LS1 Hot Cam
LS2 Timing Chain
LS7 Lifters
PAC 1218 valve springs
1/8 shortened push rods
Katech rod bolts
ATI Superdamper 10% underdrive
LS6 intake manifold with Hypertech airfilter
MN6 Transimission (stock)
3.42 rear gear (stock)
Spec stage 3+ clutch with aluminum flywheel and pressure plate; new master and slave cylinder
Tick Performance clutch remote bleeder kit
Phoenix Performance T1 exhaust (no cats/mufflers)
Elite Engineering PCV Oil Catch Can
2011 Dyno 383wrhp 380wrtq on 93 pump gas; Dyno sheet meets 2012 NASA requirements
Suspension:
Callaway double adjustable coilovers with Eibach Springs
Pfadt Spherical bushings in all control arms
GM C5 Z06 sway bars with T1 adjustable endlinks
Turn 1 rebuilt stock power steering rack with Turn 1 power steering pump
Brakes/Hubs:
AP Racing/Hardbar T1 front brake package with spare set of new rotor rings (two piece floating rotors)
Stock GM C5 Z06 rear brakes
DRM Front brake ducts with spindle mounts
SFK HD racing hubs/bearings on all four corners
Spare set of hubs/bearings
Wheels:
8 GM/Speedline 18x10.5 c5 z06 wheels
A6 tires on all, 1 set only has 1 heat cycle
Available stock C5 wheels 17x8.5 fronts and 18x9.5 rears
Electronics/Misc:
Hardwired AMB Transponder mounted on frame (included)
Traqmate complete system (not included, but negotiable)
Cool Suit system (not included, but negotiable)
I am sure I am missing information/details above, but this provides a good idea on the build. Asking price is $33,900.
I will post up some pictures later today.
If you are interested in a trailer, I will have a 28' Pace enclosed trailer for sale once the car is sold and/or could offer a package deal.
Body/Frame/Cage:
Safety:
NASA logbook
Engine/Drivetrain:
LS1 block
LS1 Hot Cam
LS2 Timing Chain
LS7 Lifters
Katech rod bolts
Suspension:
Brakes/Hubs:
Wheels:
Electronics/Misc:
Bump for Ryan.
Folks, this is a fine car, and it's fast, too.
Some other things I forgot:
Ron Davis heavy duty radiator
DRM racing oil cooler with stainless steel lines and adapter
DRM front brake ducts
Phoenix spindle brake duct mounts
I am sure there are items I forgot. Send me questions if you have any.
yea, why are you selling it!!!
Lack of time to get to the track, as well as, do all the work on the car to prep for races, at the track, and post races - I will probably look at some rental options to get my racing fix and let someone else do all the hard work . I would rather the car be used than sit in the garage right now. It is such a great car and it needs a new owner/driver.
Jerry - send me a PM with any questions you may have.
The original build of the car was full T1 and Phoenix did that prep. The car now has coilover suspension, different bars, and spherical control arm bearings, which I installed myself. I do most of the car setup myself with scales etc etc. The alignment specs are based off Phoenix's original build with some minor tweaks/tunes.
