Questions on Ball Joints
Old 05-01-2012, 01:37 PM
jlutherva
jlutherva's Avatar
Default Questions on Ball Joints
I've got a slight amount of play in the left front wheel (6 & 12:00). That's a ball joint right? How much is too much? This is just perceptible but was not there last season and the right front has no play. Also, how do you tell if it's an upper or lower ball joint? Are both replaced at the same time?
Jim
Old 05-01-2012, 01:43 PM
Falcon
Falcon's Avatar
Jim
Probably just a hub/bearing. Relatively easy to replace.
Ball joints aren't known to go bad often, and are a bear to replace.
Old 05-01-2012, 01:57 PM
jlutherva
jlutherva's Avatar
If it were a hub bearing, wouldn't it have 3-9:00 and 6-12:00 play?
Jim
Old 05-01-2012, 02:41 PM
RX-Ben
RX-Ben's Avatar
Have someone wiggle the wheel and feel the ball joints for movements. You will feel the slop if they are bad. I had a bad upper when I had 6-12 movement.
Old 05-01-2012, 02:50 PM
Falcon
Falcon's Avatar
Jim
3-9 could indicate bad tie rod end, too.
Bearings can be 6-12 and 3-9.
Old 05-01-2012, 06:12 PM
froggy47
froggy47's Avatar
Old 05-01-2012, 07:28 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
First make sure everything is properly torqued and tight. I had a tie rod end loosen up once when I first started tracking and under warranty.
Old 05-01-2012, 07:32 PM
froggy47
froggy47's Avatar
I have found that there is no substitute for getting the car up on ramps or a lift and moving stuff around while wrapping your hand around the various rod ends, ball joints, nuts. Get dirty & get answers.
Old 05-01-2012, 09:52 PM
JDIllon
JDIllon's Avatar
It is usually the lowers that go bad. I just replaced all my lowers because 2 of mine had boots that were torn. Jim, give me a call if you decide to replace them. JD
Old 05-02-2012, 03:34 AM
jlutherva
jlutherva's Avatar
That's on the agenda for today. I need to power wash the undercarriage and swap tires.
Jim
To Questions on Ball Joints
Quick Reply: Questions on Ball Joints
