Help c6 to z06 trans and diff swap
Old 05-02-2012, 12:16 AM
msracing
msracing's Avatar
Default Help c6 to z06 trans and diff swap
Need some info .. I have a 2006 c6 that I have turned into a track only car. I Have purchased a trans and a diff out of a 2009 z06 .. I want to install it into my c6. My question is will it be a direct bolt up? Or do i need to makes some mods. I know that the z06 trans and diff has it's own oil pumps and will need to make up some oil coolers... Will my torque tube fit with the z06 trans ? Will my c6 cv work on the z06 trans? Any info will be greatly appreciated
Old 05-02-2012, 01:11 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
Should be a pretty clean swap except for the cooling lines. You might have to add a cut-out) in the torque tube bell housing for the front line if your torque tube does not have an opening.
Old 05-02-2012, 04:25 PM
naschmitz
naschmitz's Avatar
Are the C6 and C6Z half shafts compatible?
Old 05-02-2012, 05:11 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Should be.
Old 05-04-2012, 09:02 AM
msracing
msracing's Avatar
well it looks like i will be changing out the c6 trans and diff and installing the z06 one next week... any quick tips that will make this easy?
thanks for the info...
regard..Manny
Old 05-04-2012, 09:12 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Mechanically speaking it should not be that bad.
Just like changing a clutch, except for the clutch part, plus hooking up some cooler lines. Do not use an air gun to drop the cradle from the car, only hand tools and the same goes for reinstalling it.
You don't want to break the retaining pins holding the bolts.
Old 05-05-2012, 12:27 AM
msracing
msracing's Avatar
thanks ajg1915 for the useful info.. i am going to replace the clutch also as i am already there ...
regards...Manny
Old 10-15-2012, 10:31 AM
MRBLONDE13
MRBLONDE13's Avatar
Default How did it go...was it a clean swap?
You never posted any follow up...would appreciate any tips you learned.
Old 10-15-2012, 11:34 AM
msracing
msracing's Avatar
its pretty straight forwards.. you can call me with any question you may have...
Manny 305-333-4445
To Help c6 to z06 trans and diff swap
Quick Reply: Help c6 to z06 trans and diff swap
