Anyone running 345/30/19 rear..any rubbing on track?
Old 05-05-2012, 09:45 AM
trapp
trapp's Avatar
Default Anyone running 345/30/19 rear..any rubbing on track?
Just order 345/30/19 for my GS..for the track (rear). Anyone having any issues with fit and rubbing?
If your are running them what front size are you using?
Tom
Old 05-05-2012, 10:51 AM
CodeBlack
CodeBlack's Avatar
C6z06 front Hoosier R6 295 30 18 front is set at negative 2.5 camber no problem. stock height. 345 30 19 rear haven't been a problem either
Old 05-05-2012, 11:03 AM
trapp
trapp's Avatar
Thanks...I just wanted to make sure to rubbing.....
I'm set at 2.5 neg front
1.5 neg rear
295 30 18 front
345 30 19 rear
No Codes correct?
No traction control, nannie issues correct?
Tom
To Anyone running 345/30/19 rear..any rubbing on track?
Quick Reply: Anyone running 345/30/19 rear..any rubbing on track?
