Toyo 888 - Odd Tire Wear
Old 05-06-2012, 07:58 AM
Dan Wendling
Dan Wendling's Avatar
Default Toyo 888 - Odd Tire Wear
I recall a thread on my question, but all searches failed to find it.
I have a set of Toyo 888's with 12 HPDE 20 min sessions and am seeing odd tire wear patterns on the driver side front. The wear is only on the driver side front, surely because the tracks are all clockwise high left side load courses.
The wear is a ridge of rubber on the leading edge of the tread pattern. It gets more pronounced as I put more laps on the tire. The wear is only on the outside set of tread patterns, inside set looks nominal.
Hope the picture is adequate to show the issue.
I run starting pressures of 26-28# on the drivers front and about a pound more on passenger front and rears. After a couple of laps I see pressures on 37-38# on all 4 tires.
Old 05-06-2012, 11:23 AM
ooldguy
ooldguy's Avatar
my new 888's look similar after 8 - 20 min. sessions at Mid-Ohio
hot pressure's 40 - 35
first thought it was the " push " in the key hole
only on the front's
Robert Dudek
Quick Reply: Toyo 888 - Odd Tire Wear
