stock mufflers vs. straight pipes gains
Old 05-08-2012, 03:01 PM
crimlwC6
crimlwC6's Avatar
Default stock mufflers vs. straight pipes gains
I'm building a track only 99 FRC. My question is does removing the mufflers and running straight pipes reduce power, add power or make virtually no difference? The car will be getting headers, x pipe and a tune before returning to the track. The forum seems conflicted on the issue based on the searches I did. If there is no performance gain then I'd leave the mufflers in and take the 40 lb weight penalty in hopes that I could run at a local track with noise restrictions. I've considered straight pipes and then when the budget recovers picking up some supertrapps. Thanks in advance,
Old 05-08-2012, 03:41 PM
spazegun2213
spazegun2213's Avatar
first, YMMV depending on exhaust, engine, etc. My ls6, gained well over 30whp untuned. I went from a stockish exhaust (hollowed cats) to American racing headers (their racing 1-7/8s) into 3" dumps. I was shocked, and told the tuner to take timing out of the top end (st-2 car). What mufflers do you have now?
Old 05-08-2012, 06:18 PM
crimlwC6
crimlwC6's Avatar
Eventually is stock (LS1) except for the custom air intake that was built to accommodate laying the radiator forward. I'll be installing kooks 1 7/8s headers w/ kooks x pipe and then getting a tune done.
Old 05-08-2012, 06:36 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
I made 10more rwtq with just my cut outs open vs modded ti mufflers. This was on my 416 with 3/4 long tubes, no cats
Old 05-08-2012, 07:18 PM
crimlwC6
crimlwC6's Avatar
Thanks for the responses. I'm guessing that it will be good for 5-7 hp on the top end for my car and 30 or so pounds off the **** end of the car. Any thoughts on the impact on torque in the lower rpm range?
Old 05-08-2012, 11:19 PM
VGLNTE1
VGLNTE1's Avatar
Increased on mine, but i have more cubes
Old 05-08-2012, 11:41 PM
sperkins
sperkins's Avatar
My '99 stock LS1 with headers etc. dyno'd 346 with ZO6 Ti mufflers and 352 with straight pipes, but I don't think it was really that much since they were done at 2 different shops and the accuracy of the higher reading dyno is in question. I'd run the mufflers if I could hear the engine during a race.
To stock mufflers vs. straight pipes gains
Quick Reply: stock mufflers vs. straight pipes gains
