C6, Heel Toe Shifting
I have a C6 that is mostly used for track days. I have been trying to get my heel/toe shifting down but the pedals do not seem to line up. I do see aftermarket pedals available but the brake pedal and gas pedal seem to be at different heights... any suggestions.. Thanks...
Jason
Jason
Received 8,928 Likes
On my C4, two C5s and the C6Z the brake pedal has always dropped to the same level as the gas pedal when I push it. All I had to do was roll the right side of my foot over to move the gas pedal.
Bill
Bill
I agree about the pedal height but it is nice to have a little larger pedal. An alternate source of pedals:
http://www.ultimatepedals.com/home.htm
with all the posts.. you dont need aftermarket pedals, you just have to be going fast and braking down hard and the pedals will line up and it is easy to heel toe on the vette it is all about timing it just right
there is a rhythm to it.. brake hard, clutch in, vroom the gas pedal and shift into gear, release the clutch, hold the brake, feel and ease off the brake and gas out of the corner.. youll know when you get it right..
it just the being like a machine part that is hard, staying consistent under pressure..
I heel toe on every down shift on the street, even w/light braking. I can do this because I have a pedal extension on the brake pedal so that the 2 are closely spaced. Any height difference I adjust for by rolling my foot and I have a big foot. What I hate is for the brake pedal to get below the gas pedal; that I've fixed w/SRF fluid and ss caliper pistons & Ti shims for the track.
Heel and toe is such a misleading term. It's actually the right side of your foot. Before you buy those fancy pedals find a piece of plywood and make your own. Cut it so that the left side of the accel. pedal is close to the brake. Bolt it onto you stock pedal and then glue sandpaper to it.
When it comes the to height you want the accell. pedal at the same height at a depressed brake pedal.
Richard Newton
Newton's Laws
Richard Newton
Newton's Laws
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
At Bondurant's I had to use the factory C6 setup to do my H/T. On that particular weekend it was actual H/T. I had to use my toes on the brake with my heel on the throttle with my foot almost completely horizontal. The ergonomics are important but not as important as rhythm and timing. One can adjust with a little practice. I got really smooth in just a few laps. However, it was nice when I got back to my own car with the Elite Engineering pedals. Deal with what you have and don't go overboard until you are absolutely sure what you need. I got the oversized EE pedals and should have gotten the slightly oversize.
