viper gt2 cars will run a 8.0L
Old 05-22-2012, 10:20 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default viper gt2 cars will run a 8.0L
http://badboyvettes.com/695
Now thats some BS
Old 05-22-2012, 10:57 PM
rustyguns
rustyguns's Avatar
Now thats some BS
damn.. Can we pop a stroked LS7 in ours real quick?
Old 05-22-2012, 11:21 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
ACO regulations define the minimum engine displacement as 5.5L
Old 05-22-2012, 11:26 PM
KBow_Photo
KBow_Photo's Avatar
St. Jude Donor '12
ask BMW about ACO regulations
Old 05-23-2012, 07:43 AM
VGLNTE1
VGLNTE1's Avatar
It better have to weigh 3200 lbs
Old 05-23-2012, 09:20 AM
BuckeyeZ06
BuckeyeZ06's Avatar
It does. And has twin 40mm restrictor plates.
Old 05-23-2012, 08:31 PM
TLGunman
TLGunman's Avatar
Restrictors are crazy small.
Old 05-23-2012, 09:52 PM
travisnd
travisnd's Avatar
They got a waiver on displacement. The car will be heavy and restricted.
Old 05-23-2012, 11:21 PM
Everett Ogilvie
Everett Ogilvie's Avatar
Yep, this is likely a big disadvantage for them - having to use the big (heavy) motor and restrict the hell out of it. That car would be much faster with a smaller lighter less restricted motor. This is why the Vettes will kill it.
Old 05-24-2012, 10:55 AM
sundiego
sundiego's Avatar
Shorter races, tighter tracks, yes. The restrictor plates will cause them to shift at about 4000 rpm. The engine will mave massive torque, and will be amazingly durable in the endurance races with that 4000 rpm 'redline'.
The motor is aluminum, and not too heavy.
Old 05-24-2012, 11:01 AM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
Im rooting for the vipers!
Old 05-24-2012, 12:11 PM
VGLNTE1
VGLNTE1's Avatar
I will give them one thing....they are better looking
Old 05-24-2012, 01:58 PM
95jersey
95jersey's Avatar
Even if they restrict, it will still produce tons of torque. They will just build the motor around the restictor, just like they did with the 7.0L. If I remember the GT1 7.0 had crazy torque numbers vs. horsepower due to the restrictors. Also, the article makes a good point, with lower revs and high restriction, the motors should be VERY reliable compared to a strung out 5.5L. The motor will be all aluminum, it won't be overly heavy. I think the street viper is right around the weight of a ZR1.
Old 05-24-2012, 03:43 PM
VGLNTE1
VGLNTE1's Avatar
street snake is 3300 lbs...even lighter than a ZR1
Old 05-24-2012, 04:25 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
screw Fehan!
Old 05-24-2012, 04:32 PM
Timz06
Timz06's Avatar
The C6r produces 470hp @ 4,800 rpm, so it is not exactly 'strung-out' either. Both are setup for torque.
Old 05-24-2012, 05:13 PM
VGLNTE1
VGLNTE1's Avatar
Originally Posted by timz06
the c6r produces 470hp @ 4,800 rpm, so it is not exactly 'strung-out' either. Both are setup for torque.
8.0>5.5
To viper gt2 cars will run a 8.0L
Old 05-24-2012, 05:15 PM
VGLNTE1
VGLNTE1's Avatar
Originally Posted by John Shiels
screw Fehan!
I agree, but...i look past the politics and just enjoy rooting for the home team. i love all the cars and the sport in general. Who cares about all the BS behind closed doors.
Old 05-24-2012, 08:47 PM
TLGunman
TLGunman's Avatar
Me too
Old 05-24-2012, 09:50 PM
Everett Ogilvie
Me too
I think that's called a "conflict of interest".
Quick Reply: viper gt2 cars will run a 8.0L
