What PSI to start with for R6's?
Old 05-28-2012, 01:49 AM
rayk
rayk's Avatar
Default What PSI to start with for R6's?
Stock 2011 GS setup. What cold PSi to start with on HPDE's. What would be the hot PSI to shoot for?
Thanks.
Old 05-28-2012, 05:24 AM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
Thanks.
Your cold PSI will be dependant on how much PSI you will be increasing which varies on speeds you will see and your talent level.
Typically a beginner will see a 3-4lb increase, intermediate 5-8 and a seasoned driver will see 8-11.
Look for a hot temp of 36.
Mike
Old 05-28-2012, 05:59 AM
brkntrxn
brkntrxn's Avatar
Agree with Mike
Old 05-28-2012, 09:50 AM
J.R.
J.R.'s Avatar
Default R6 pressure
Mike
What Mike said.
Old 05-28-2012, 10:16 AM
BEZ06
BEZ06's Avatar
Here's Hoosier's own recommendations:
http://www.hoosiertire.com/rrtire.htm
In there you can read about heat cycles and proper curing after the initial heat cycle; chassis setup (2.5 to 3 degrees of camber); and Hoosier recommended pressures for a car of our weight (27-33 psi cold and 38-43+ psi hot).
Butt.....that's just the manufacturer's recommendations.
Bob
Old 05-28-2012, 10:21 AM
GeorgeZNJ
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
The first day I always start cold 30 psi. I maintain 28 psi hot from there. Some guys will run a different psi from front to rear. I have seen an increase of 10-12psi fromcold to hot, so check each tire after each session. You can also monitor your tires with a digital thermoter checking the tire temps along with the pressure gauge
Old 05-28-2012, 11:08 AM
rayk
rayk's Avatar
That's what I needed. Thanks everyone.
To What PSI to start with for R6's?
Quick Reply: What PSI to start with for R6's?
