full splitter and cooling issues...what i did
Old 05-28-2012, 02:21 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default full splitter and cooling issues...what i did
I've gotten a ton of pms about how I'm keeping the fluids cool after I did the splitter and undertray. As most see I did not cut the bumper like most do with the acp set up. So here's what I did.
Since my car does see a lot of street use still and cooler days, I couldn't have just one system to keep it cool, like cutting the bumper. So I cut out the front plate area and added some screen. I then used thin lightweight plastic panels and boxed in the rad area. The pic can't show it but I have panels cut to fit just right down the sides of the frame to the bottom of the bumper and meets with the rad. I think used a piece on top to enclose the whole area the rad and oil cooler are. When its not 100 degrees or beating it on the track, I just put the front plate cover on and I'm good. I've yet to see oil hit 250 even on the hottest day.
Old 05-28-2012, 03:05 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
PM sent....
Old 05-28-2012, 05:20 PM
mountainbiker2
mountainbiker2's Avatar
What about adding a DeWitts radiator?
Steve A.
Old 05-28-2012, 06:07 PM
TriplBlk
TriplBlk's Avatar
Steve A.
Dewitts is twice if not 3 times the thickness of oem which is why is cools so much better. This is good to even use in conjunction with VGLNTE's nice setup
Old 05-28-2012, 07:41 PM
VGLNTE1
VGLNTE1's Avatar
Until I find the need for it, stock has worked just fine. Add enough cooling the proper way and 1000$ radiators are not needed for cars that run 20-30 min at a time
Old 05-28-2012, 07:42 PM
stevensa
stevensa's Avatar
Can you feel a difference with this setup, any lap time data?
Old 05-28-2012, 07:46 PM
VGLNTE1
VGLNTE1's Avatar
For the cooling? Wouldn't effect lap times at all. You mean the aero?
Old 05-28-2012, 08:43 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Bid rads make a big difference
Old 05-28-2012, 08:55 PM
TriplBlk
TriplBlk's Avatar
Could you explain the benefits? I figured the bigger ones were just more weight?
Old 05-28-2012, 09:03 PM
RDnomorecobra
RDnomorecobra's Avatar
right behind the license plate cover you run into the radiator shroud right? did you cut through that so the air gets to the rad? i can see it in the pic so you didnt remove it altogether.
Old 05-28-2012, 09:50 PM
VGLNTE1
VGLNTE1's Avatar
Took it out and Junked it. Imagine just a big tunnel going right to the rad now
Old 05-29-2012, 06:02 PM
stevensa
stevensa's Avatar
Yes from the aero.
Old 05-29-2012, 06:05 PM
VGLNTE1
VGLNTE1's Avatar
Nope, not yet, but I know it will do wonders. I can tell 100% just on street testing
To full splitter and cooling issues...what i did
Quick Reply: full splitter and cooling issues...what i did
