Brake fluid for towing
Old 05-31-2012, 12:51 PM
c4pappy
c4pappy's Avatar
Default Brake fluid for towing
This may be a bit off topic, but if you tow your race car, I could use your opinion.
I know many of you tow. I have a Chev van I use and it's time to change the brake fluid (uh, like 3 years ago).
I thought there was a thread on here about it but I can't find it.
What fluid do you like for your tow vehicles? Best place to buy?
Old 05-31-2012, 05:09 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
Castrol LMA for tow.
Jim
Old 05-31-2012, 05:44 PM
c4cruiser
c4cruiser's Avatar
A good quality DOT3 fluid will work fine. You really aren't going to subject a DOT3 fluid to the high brake temps that track use sees. But it certainly doesn't hurt to do a fluid flush each year if you are towing any appreciable amount.
As mentioned Castrol LMA is a very good fluid. Another one is the Ford Motorsports HD fluid (yes, F***) Valvoline is another good fluid.
The Ford fluid is typically available from a Ford dealer; the parts counter should have it. It comes in small 8 oz bottles so you can buy enough for what you need and won't have fluid left over in a quart jug.
The Castrol and Valvoline fluid should be available at most chain parts stores.
Old 05-31-2012, 06:46 PM
AU N EGL
AU N EGL's Avatar
Jim
and this is what we use in our normal cars and trucks
Old 06-01-2012, 07:14 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I agree that a brake flush every year is a good idea on the tow vehicle. I use a Motive Bleeder and use Amsoil DOT4 - the same stuff I put in the race car. I don't mind spending the extra dollar or two for the DOT4 fluid and I feel better having a higher temp fluid that I know I can depend on in the tow vehicle. BTW, it's a 2002 Yukon.
Old 06-01-2012, 10:01 AM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Change it every two years.
I admit I was lazy and had the dealer do it when the Tahoe was in for an oil change.
Truck has close to 50K miles
Old 06-01-2012, 08:39 PM
c4pappy
c4pappy's Avatar
Thanks for the insight. I'll try the Castrol and i need to be more diligent.
To Brake fluid for towing
Quick Reply: Brake fluid for towing
