new front breather design
Old 06-01-2012, 12:11 PM
z06801
z06801's Avatar
Default new front breather design
Its not as big as hole as it looks, all ducted to radiator. Top will feed oil cooler. Z06 screens are blocked
Old 06-01-2012, 01:15 PM
el es tu
el es tu's Avatar
Old 06-01-2012, 04:11 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
Wicked. Would be curious on how it effects the front aero.
Old 06-01-2012, 04:23 PM
crease-guard
crease-guard's Avatar
Now that all that air is going through the radiator, you need a vented hood
Jay
Old 06-01-2012, 05:31 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
The more air in the more drag and lift.
Old 06-01-2012, 08:09 PM
z06801
z06801's Avatar
Jay
Thats the next project to tip the radiator forward and make carbon fiber duct work on the back side that sends it though a vented hood have a carbon hood already for the vents
Of course you are right, but the opening only turns out to be about 157 square inches just slightly bigger than a C6 mouth and the Z06 screens are blocked, with the ducting and vented hood we'll give it a try.
Old 06-02-2012, 09:43 AM
John Shiels
Vented hood like I have or in general work great.
Old 06-02-2012, 11:24 AM
AU N EGL
AU N EGL's Avatar
that could suck the whole dead possum up there.
Old 06-02-2012, 02:36 PM
z06801
z06801's Avatar
Scrape it right off the ground too How big did your front opening end up being? In the summer, Miller here in Utah is very hot and heat is always a fight. Here is a picture of the ducting just laid up some flat sheets of carbon for the sides, the bottom is just a simple carbon tray with 90* sides not to high tech or pretty for sure, but fun to mess around with. Have to redo when the radiator is laid forward
Old 06-03-2012, 04:44 AM
sebdavid
sebdavid's Avatar
Aren't you worried about debris getting to the radiator? I don't see a mesh grille...
Old 06-03-2012, 02:40 PM
z06801
z06801's Avatar
for sure, have one its just not installed in the picture, the carbon surround still needed a little work so it was sitting in place for the picture.
Old 06-03-2012, 03:07 PM
sperkins
sperkins's Avatar
Batmobile-ish
Old 06-03-2012, 03:44 PM
AU N EGL
AU N EGL's Avatar
Mine is 5" high by 14" wide
and YES we did get that dead possum too.
Old 06-03-2012, 07:20 PM
GeorgeZNJ
Support Corvetteforum!
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
Racing with extra cooling and a free lunch
Old 06-04-2012, 08:50 AM
Falcon
Falcon's Avatar
When I saw that front end it reminded me of what a friend of mine did to his car when we were in high school.
Old 06-12-2012, 11:19 AM
z06801
z06801's Avatar
just saw this thanks for the new avatar love the Stones
To new front breather design
Quick Reply: new front breather design
