DRM Master Cylinder or fix my ABS?
Old 06-01-2012, 04:32 PM
moespeeds
moespeeds's Avatar
Default DRM Master Cylinder or fix my ABS?
Looks like the ABS controller on my '00 FRC is shot. Still some troubleshooting to do, but I'm not too hopeful. I was considering trying a new controller (used) which as you guys know run about $700+ and aren't really a sure fix, or spend the $600 and get the DRM M/C with the bias adjustment? The car is track only. Where would you guys spend the money?
Old 06-01-2012, 04:50 PM
moespeeds
moespeeds's Avatar
Ok nevermind. I just spoke to Randy at DRM, and he was good enough to give me his objective opinion. He said with no ABS controller, leave the system stock, or go with a dual M/C setup. Neither the spring or the adjustable M/C that they sell will do me any good.
Quick Reply: DRM Master Cylinder or fix my ABS?
