camber/toe tech questions...c6(non-z06)
I have 1/8" toe in, in the front. 2.7* camber left, 2.9* camber right.
I have 1/4" toe in, in the back. 1.7* camber left, 1.9* camber right.
This was my first attempt at a home alignment job in prep for Road Atlanta June 16-17. I am worn out after fighting with guess-n-check for 5 hours. Am I good to go? Or do I need to keep working on it to get less toe-in in the front or back?
I feel like I need less camber on my right side, perhaps even more on my left (for Road Atl, at least). What do you think?
Should I have just spent the $60 and let someone else do it for me?!!! (probably so)
Not a bad alignment.........Mine cost about 65 bucks..
you need zero, or about 1/16" max toe OUT in the front. Either way, you need to get it closer to zero. Camber is fine.
just loosen each front tie rod about 2 flats, and you should be closer.......
Received 8,926 Likes
For the OP: If you are getting 4 wheel alignments done for $60 that is a really great price if the person doing them is any good. The advantage to doing them yourself is you probably get a better job and when you switch back to the street alignment you don't have to pay again. Most people set there cars up so all they have to do to change from street to track is subtract or add washers at the upper control arm mounts, then adjust toe based on marks they put on the tire rods. That way you can switch back and forth without a lot of the hassle and just do a thorough check every now and then.
Bill
Actually it isn't the Hex Jam nuts that hold the setting. It is the hex shaped portion of the tie rod itself. Each flat should be about a 1/32 change.
Bill
Bill
Bill
Bill
I'm doing NASA's Road Atlanta next weekend in HPDE2. After that I'll go back to my previous settings according to Pfadt's street/track setup. I had 1.2* front and .8* back and at Memphis, in 2 days, I still wore much more on the outside edge. More camber should make it wear more evenly at Road Atl.
what characteristics will happen if the OP used 1/8" toe in for the front?
The car wants to go straight and the wheel typically stays on center down the straights. That makes sense as the front tires are pointing towards each other. Some drivers feel like it's not as "darty" feeling on turn in.
I actually like some toe out front because I mostly auto-x and it seems to help with turn in but a road course may be different.
Ive tried 1/4 out but it seemed to swing the *** lose on entry so I dialed it back to about 1/8 and Ill test this weekend.
This is my last race on street tires so Ill have to learn what the new ones like.
The washers that come with the car give you about 0.4 degrees each when removed.
You'll burn through the front tires in short order too with the way it is.
I couldn't imagine trying to drive a Corvette at the limit with 1/8 front toe in.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
What do you have for tires? Could be enough camber...might be to much.
Also I would run toe out at the front, toe in at the rear. The amount of that is going to be what you feel comfortable with as far as driver feel as well as tire wear.
Get some tire temps while you are there, and record what you change if anything.
Will it screw up the thrust angle if you adjust one side camber to even both sides out? I adjusted both rear sides evenly on the cam bolts and after settling it on an auto-x course the pass side is -.5 camber and the driver side is -1.5(where I wanted it).
My thrust angle is good now.
Can I do the camber+toe on the pass side wheel only and be ok?
Your camber is good enough, for now.
It's easy to change toe at the track if you bring ramps.
Remember toe (in or out) will kill the tires street driving.
Here are some good diagrams that explain alignment. They take a while to load. Scroll down to thrust.
http://www.familycar.com/alignment.htm
