18" square set up...what size tires you run?
Old 06-03-2012, 11:02 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default 18" square set up...what size tires you run?
I've been running it for quite some time, but I'm curious as to what you guys run...
Old 06-03-2012, 11:24 PM
crimlwC6
crimlwC6's Avatar
305s
Old 06-03-2012, 11:34 PM
Dirk Miller
Dirk Miller's Avatar
Default on my C6
Currently on my C6 I am using 285 645 R18 & 305 645R18
Old 06-03-2012, 11:44 PM
brkntrxn
brkntrxn's Avatar
Fast guys do it on 275s
Old 06-04-2012, 07:25 AM
VGLNTE1
VGLNTE1's Avatar
Ive used a set up that had the front and rears the same height. Everytime I took a fast corner the cars AH took over and got all squirrly.
Old 06-04-2012, 08:45 AM
JerryTX
JerryTX's Avatar
Even with all the nannies turned off?
Old 06-04-2012, 10:29 AM
MartyZ51
MartyZ51's Avatar
295 up front and 335 in the rear on a base C6 with 18" CCW wheels. There is just a whisper of space between the drivers side rear inner fender and the tire. The passenger side has more clearance but neither rub.
Old 06-04-2012, 10:45 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
305s all the way around. They barely rub in the rear but still all good.
[IMG][/IMG]
Old 06-04-2012, 10:51 AM
bsalie99
bsalie99's Avatar
for autox I use 315 rears and 295 or 285 fronts. the 285 Hoosier A6 's are slightly wider than the 295 on the 18x10.5 rim. I might try 315's square next
Old 06-04-2012, 10:52 AM
spazegun2213
spazegun2213's Avatar
315/30/18.... on 10.5's. Yes you cant use 100% of the steering angle in the front because the wheels WILL hit the A arms... but its totally worth it.
I do have a set of 335's on some 12" rear wheels though, but they are mexiflush (eg stick out 1/2"
Old 06-04-2012, 10:58 AM
travisnd
travisnd's Avatar
Originally Posted by brkntrxn
Fast guys do it on 245s
Fixed for you
Old 06-04-2012, 11:09 AM
mountainbiker2
mountainbiker2's Avatar
335 square.
Old 06-04-2012, 11:23 AM
spazegun2213
Originally Posted by mountainbiker2
335 square.
what size wheels are you running up front? and how much steering angle can you use? I know my 10.5s limit the steering a lot!
Old 06-04-2012, 11:45 AM
mountainbiker2
I just noticed that the OP said 18" wheels. I'm 17" wheels. 17x11.5 17x12. I put stops on my steering rack. I believe my steering wheel turns 1 1/4 turns one direction. Plus I had to do some cutting on the backside of the fender liner.
Old 06-04-2012, 11:59 AM
spazegun2213
have any pictures of the cutting needed?
also, how did you install those stops?
VGLNTE1
VGLNTE1's Avatar
nannies on
Old 06-04-2012, 12:13 PM
spazegun2213
nannies on
sissy. Seriously, all that stuff is only good for the street. Turn it off for the track. If you cant drive your car on track without those on... go back to street tires. Yes, that was a mean statement, but its true. Gm's AH stuff is really only meant for the road, and there WILL be times it will chime in on the track.
The C5's system is so useless that I'd love to 100% disconnect it if I would not lose ABS in the process. So Its part of my start up habit, I always remember to press that button
To 18" square set up...what size tires you run?
Old 06-04-2012, 12:46 PM
VGLNTE1
VGLNTE1's Avatar
but what if i hit the grass and mess up my wax job?
Old 06-04-2012, 01:57 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
I get only slight rub with 18" 315's on front. Car is lowered with 1050 pound spring. I have only 1 1/4" clearance with car resting. I do have shims installed by D. Popp in the steering rack to limit the stop to stop travel.
Old 06-04-2012, 02:45 PM
Armycop
Armycop's Avatar
315' on 18's all 'round. QA1 coilovers with rebound set to 11 front 10 back and spring height all the way up, no rub on the fender wells. No lock to lock steering though, or I rub the brake ducts in the inner fender well.
Quick Reply: 18" square set up...what size tires you run?
