Breaking in a new crate motor for racing
Blew my engine at last race. Have a new LS6 crate motor being installed but won't have much time for break in.
What is some good advice for doing the break in properly so I can enjoy a relatively long racing life from it?
Thanks,
Matt
Thanks,
Matt
Since it's a track car, it's hard to put miles on b4 you run it.
A new street motor is going to be tight & run hot, no way around it.
I would self impose some lap limits, watch the gauges closely, at the sign of any heat issues do cool down or pull to pits & drive around periphal roads EASY.
Maybe get 100-200 miles on it, dump oil & filter & good to go.
I wouldn't run it over 5500 if it were mine. Maybe once a lap.
Maybe dino oil, but I would try to get advice from someone who has done it. Maybe not.
Let us know.
Let us know.
If it's a GM crate motor then it should already be run-in on the dyno and ready to go. The break-in period in a new street car is really for the transmission and rear end to develop good wear patterns for long service life.
If it's a newly built motor with no run time, then I'd do the dyno thing for 30 minutes, change the oil and go.
If you cannot run it on the street. Gm probably runs them for 2-3 minutes or even less to see the power and all is OK. Put a fan in front if you are idling it. After the first session I would run it up to redline few times. Many happy miles ahead!
