97-11 Front or Rear HD Racing Bearing - Except ZR1
Former Vendor
St. Jude Donor '13
1997-2011 Front/Rear HD Racing Bearing - Except ZR1
Will Fit C5, C6
$415.00 each
http://www.xplosiveperformance.com/9...KF_p_2445.html
Will Fit C5, C6
Interchangeable from Front to Rear
ZR1 Technology
10 Micron Run-out
Increased Durability
You gain increased stiffness for better brake performance under high loads. Under race competitive use, you may go an entire season without replacement. This unit is designed to provide a high stiffness during cornering, reducing piston knock-back and the need to trail brake. It's also designed for durability and to maintain preload at a sustained loading of 1.2g. All this adds to faster lap times and better driver feedback.
ZR1 Technology
10 Micron Run-out
$415.00 each
Former Vendor
St. Jude Donor '13
Will Fit C5, C6
Will Fit C5, C6
ZR1 Technology
10 Micron Run-out
ZR1 Technology
10 Micron Run-out
Former Vendor
St. Jude Donor '13
Will Fit C5, C6
Will Fit C5, C6
ZR1 Technology
10 Micron Run-out
ZR1 Technology
10 Micron Run-out
Former Vendor
St. Jude Donor '13
Will Fit C5, C6
Will Fit C5, C6
ZR1 Technology
10 Micron Run-out
ZR1 Technology
10 Micron Run-out
