Looking for info on batteries for C6Z06?
Old 06-08-2012, 03:59 PM
JDIllon
JDIllon's Avatar
Default Looking for info on batteries for C6Z06?
What battery are you running for C6Z06 rear mount?? I'm considering the Deka? ETX18L? Good? Bad? why? will a regular battery charger work for this battery? Note- I know there were lots of battery threads a while ago, but nothing lately. Thanks JD
Old 06-08-2012, 04:47 PM
Aardwolf
Aardwolf's Avatar
JD, got your email, figured I would just reply here. I have the ETX14L and it has worked well for my combo. It cranks just fine in the cold, but doesn't have much reserve power. When my 355 10.5:1 compression rebuild was new and tight it barely turned it over. But cranks fast after that. I've been happy with it! I have used a normal charger on it but mostly use a newer one that recognizes AGM etcetc.
Old 06-08-2012, 10:54 PM
db2xpert
db2xpert's Avatar
Braille 2015 with Katech foam spacer case.
Keep the tender on it when parked.
Saves 20#.
My '07 would kill the stock battery in less than 3 wks of sitting in the garage.
Been looking at the Shorai to save another 10#, but a chunk more money.
To Looking for info on batteries for C6Z06?
Quick Reply: Looking for info on batteries for C6Z06?
