Any issues with running 18x9.5 rears with 18x10.5 fronts for a wet setup?
Old 06-08-2012, 06:32 PM
moespeeds
moespeeds's Avatar
Default Any issues with running 18x9.5 rears with 18x10.5 fronts for a wet setup?
I've got 2 C5 wagon wheel rears sitting here 18x9.5 but they won't fit over my Wilwood brakes in the front, but they fit the rear fine. I'm trying to scrape up a set of wheels to keep a set of wet track tires on. Because of the brakes up front it looks like I need a Z06 rear to get the proper offset. Any issues with running a 9.5" rear wheel and a 10.5" front wheel other than being politically incorrect? I'll be running a square setup same size tires all around.
I know I could get longer studs and use an offset but it's gonna be like 20mm or .8" and that's pretty damn big.
Old 06-08-2012, 07:19 PM
moespeeds
moespeeds's Avatar
Nevermind, Bob at House of Wheels hooked me up with a set of ZR1 18x9.5 fronts to match my C5 rears. Thanks again Bob.
Quick Reply: Any issues with running 18x9.5 rears with 18x10.5 fronts for a wet setup?
