14" Alcon Brake kit for sale cheap
Old 06-09-2012, 10:06 AM
FlamingZ06
FlamingZ06's Avatar
Default 14" Alcon Brake kit for sale cheap
This is a chance to save almost a grand off of a brand new in the box Alcon brake kit. This is a true race piece that you can run on the street, no compromises. It features
Advantage Extreme 6 piston monoblock calipers
Stainless steel pistons (not aluminum, which only belongs on the street)
No dust boots, instead a second inner seal to block road grime, which won't cook under heavy track use.
365mm x 32mm Alcon rotors
Aluminum hats and attaching hardware already assembled
Brackets
Alcon part number is BKF9751Y66 and retails for $4113.00
I would compare this kit to the Brembo GT-R at less than half the cost.
This kit will work great on a C5 or C6, Z or not.
Lines not included (since they vary depending on the car), but they are available from Hoerr Racing Products.
$3220
PM or call Tom if interested. 205-283-5158
Old 06-09-2012, 11:27 AM
Rednels
Rednels's Avatar
That's beautiful. Good luck with the sale.
Old 06-25-2012, 09:26 AM
FlamingZ06
FlamingZ06's Avatar
These are still available.
To 14" Alcon Brake kit for sale cheap
Quick Reply: 14" Alcon Brake kit for sale cheap
