Anyone running without the stock EVAP system?
Old 06-14-2012, 02:38 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Default Anyone running without the stock EVAP system?
Like the title says, have any of you guys deleted the stock EVAP system?
Old 06-14-2012, 07:04 PM
dfinke23
dfinke23's Avatar
Anyone?
Old 06-14-2012, 08:07 PM
geerookie
geerookie's Avatar
Yes. I pulled it out last winter.
Old 06-14-2012, 11:16 PM
dfinke23
dfinke23's Avatar
Any issues? Did you delete the sensor with HP tuners so it wouldn't throw a code? Did you cap the line stubbed up by the cowl or remove the line altogether? Are you doing anything about pressure buildup, or just open venting?
Old 06-15-2012, 08:48 AM
geerookie
geerookie's Avatar
All lines and unneeded solenoids/parts are removed.
Open air vented just like the old days.
I set all the EVAP codes to No Error with HP Tuners.
I did leave the codes for fuel tank pressure turned on just in case. They trigger if the pressure gets above 2 or 3 psi.
Old 06-15-2012, 05:58 PM
dfinke23
dfinke23's Avatar
I know there is one solenoid under the hood, are there any others on the fuel tank end? Also,what did you do with the connectors to the solenoids?
Thinking about getting rid of the under the hood stuff, capping the port and leaving the rest, then setting the codes to no error. See any issues with that?
To Anyone running without the stock EVAP system?
Quick Reply: Anyone running without the stock EVAP system?
