Advice; Del-a-lum lca bushings?
Old 06-18-2012, 03:36 PM
Crepitus
Crepitus's Avatar
Default Advice; Del-a-lum lca bushings?
I am collecting parts to freshen the suspention on a 84 C4. DE's AX and limited street. Startin out with 650# front and 515# rear. The car will probly see 275 slicks on 10" wheels as things get sorted out. I dont expect to need offset lower bushings (adj uppers).
My questian is poly or del-a-um in the front lowers? The del-a-um/aluminum is a few more bucks but if it works better I dont mind.
link; http://www.summitracing.com/parts/GLS-1060/?rtype=10
Dave
Old 06-18-2012, 10:49 PM
trackboss
trackboss's Avatar
Del-a-lum is a better choice if there is no misalignment needed between the control arm pivot and the pocket it goes into.
Quick Reply: Advice; Del-a-lum lca bushings?
