Beyond dirty fluid, sticky clutch pedal?
Old 06-24-2012, 11:28 PM
froggy47
froggy47's Avatar
Default Beyond dirty fluid, sticky clutch pedal?
I'm sure it's been so maybe someone that has been thru it can post me a link.
The fluid is ALWAYS fresh Wilwood 570 or better. It ONLY happens when driven hard 1 & 2 gear autox & it always goes away.
The engage/disengage is good just the pedal does not pop up all the way.
Stock c5z 45k miles.
The pedal spring is in & I guess I can try the delete but it seems to me that's a bandaid to whatever is really going on with the system.
TIA
Quick Reply: Beyond dirty fluid, sticky clutch pedal?
