3.90 and short 5&6 gears : is that good idea?
Old 06-25-2012, 02:34 AM
BossV8
BossV8's Avatar
Default 3.90 and short 5&6 gears : is that good idea?
My transmission or rear differential is singing. It means my gear box will be opened in august to see if the are bearings to be changed.
As the gear box will be opened, I was wondering if it was a good opportunity to replace my 5&6 gears with shorter models from rpm transmission ?
> is it a quick operation once the gear box is open?
> will that be a good move for my track days?
> is there any other parts to be reinforced to get the gear box better (sturdier and better shifting)?
My C5 is a 1999 model (Europe) with intake, headers and 3.90 stage two. I use it on road a little bit and on tracks.
Thanks.
Old 06-25-2012, 09:54 AM
JVetthead
JVetthead's Avatar
3.90 is great for the street, perfect for auto-x, good for short road course but alot of shifting for fast road course. I did the short 5-6 swap and it works great for fast 5th gear tracks.
3.90 diff for sale here http://forums.corvetteforum.com/c5-p...f-vararam.html
Old 06-25-2012, 10:33 AM
BossV8
BossV8's Avatar
You mean you have 3.90 + shorter 5&6 or just shorter 5&6?
I actually have 3.90 already.
Old 06-25-2012, 10:55 PM
JVetthead
JVetthead's Avatar
HAD both, went back to a 3.42
hence the 3.90 for sale
Old 06-26-2012, 01:56 AM
BossV8
BossV8's Avatar
I understand. After thinking about it, I think I'll stay with my 3.90 and normal gear as I rearely use 5 on track.
To 3.90 and short 5&6 gears : is that good idea?
Quick Reply: 3.90 and short 5&6 gears : is that good idea?
