Square Setup on a c6 z06
Old 06-26-2012, 01:24 PM
MP3
MP3's Avatar
Default Square Setup on a c6 z06
I used the search function and couldn't find what I was looking for. I'm sure this topic has been covered a million times though. I'm running stock C6 Z06 wheels, but want to drop to 18's all the way around because they will be lighter and more tire choices. which size wheels can I go with front and rear and still keep the traction control and active handling from messing with the handling of the car?
thanks
Old 06-27-2012, 02:56 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
I thought square meant same size tires on all 4 wheels. Is that what you want or are you just looking for front and rear recommendations on 18" wheels?
In running 315 F 345 R on 18" CCWs
Old 06-27-2012, 09:37 PM
VicCaerter
VicCaerter's Avatar
I had no issues running R888s all around with 275s up front and 335s out back on an 18x12.
To Square Setup on a c6 z06
Quick Reply: Square Setup on a c6 z06
